Home » Eclipse Projects » Rich Client Platform (RCP) » toggle state
toggle state [message #549942] Wed, 28 July 2010 14:18 Go to next message
Missing name Mising name is currently offline Missing name Mising nameFriend
Hello.
I have made a command, it's represents for toggle button in the main toolbar, but it has a state (true or false, select or not select).
But I have a problem I don't want remember the state between sesions of eclipse, what do I make???
My command:
 <command
            category="Favorites"
            categoryId="com.quaityeclipse.favorites.commands.category"
            description="Open tha Favorites view if it is not already visible"
            id="com.quaityeclipse.favorites.commands.openView"
            name="Open Favorites View">
        <state
                   class="org.eclipse.ui.handlers.RegistryToggleState:false"
                   id="org.eclipse.ui.commands.toggleState">
        </state>
</command>
I want the toggle false when the sesion begins.
Thanks a lot
Jose
Re: toggle state [message #551035 is a reply to message #549942] Wed, 04 August 2010 22:26 Go to previous messageGo to next message
Wim Jongman is currently offline Wim JongmanFriend
Hi Jose,
What does the handler code say?
Best Regards,
Wim Jongman
Eclipse Twitter
-- Too much coding lately, I find myself ending sentences with a semicolon
Ian Bull
> Hello.
> My command:
> <command
> <state
> </state>
> </command>
> Thanks a lot
> Jose
Re: toggle state [message #551346 is a reply to message #549942] Fri, 06 August 2010 05:06 Go to previous messageGo to next message
Prakash G.R. is currently offline Prakash G.R.Friend
Add this parameter to the command's state:
<parameter
name="persisted"
value="false">
</parameter>
See: http://bit.ly/CommandsTutorial for more details
- Prakash
Platform UI Team, IBM
www.eclipse-tips.com
Re: toggle state [message #551712 is a reply to message #551346] Mon, 09 August 2010 09:57 Go to previous message
Hello.
Thanks for your answer.
I have made this:
 <command
            <state
            <parameter
			name="persisted"
			value="false">
	    </parameter>
            </state>
      </command>
But the state is remember still.
Is my code wrong?
Thanks a lot
Jose
Previous Topic:toolbar command enablement
Next Topic:Problem closing a view unless it is active
Current Time: Sun Feb 18 03:32:06 GMT 2018
Powered by FUDForum. Page generated in 0.01958 seconds
