Home » Modeling » Papyrus » when will papyrus be supporting C++ code generation?
icon5.gif  when will papyrus be supporting C++ code generation? [message #549755] Tue, 27 July 2010 20:12 Go to next message
Shawn  is currently offline Shawn Friend
I noticed the earlier version of Papyrus, before it became an eclipse project had an add-in to allow C++ code generation of the classes created in a UML diagram. are there any plans to reinstate that functionality? If not can anyone recomend a program or plugin that has that functioality?
Thanks Very much Very Happy
Re: when will papyrus be supporting C++ code generation? [message #550337 is a reply to message #549755] Thu, 29 July 2010 23:34 Go to previous message
Remi Schnekenburger is currently offline Remi SchnekenburgerFriend
There are currently no plans to migrate the old C++ generator we had in the previous Papyrus project. It has some old dependencies towards other plugins, like the acceleo text generator, which has been promoted as an Eclipse project too. So there is a small amount of work to do on it.
It will be perhaps updated in the next months, but will not be part of the Eclipse standard Papyrus releases. I can't recommend you any other C++ generation plugins, perhaps some other Eclipse users could advise you, or you could find a plugin located in other web sites.
RĂ©mi
Remi Schnekenburger
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Previous Topic:Problem with model-view update
Next Topic:when will papyrus be supporting C++ code generation?
Current Time: Sat Apr 21 00:27:52 GMT 2018
Powered by FUDForum. Page generated in 0.02085 seconds
