Home » Eclipse Projects » Standard Widget Toolkit (SWT) » [SOLVED] Installing the examples from p2 repository zip(The examples installation process as described in the available documentation fails to see the repository content)
[SOLVED] Installing the examples from p2 repository zip [message #549752] Tue, 27 July 2010 19:55 Go to next message
Amenel Voglozin is currently offline Amenel VoglozinFriend
Hi all,
I would like to run the SWT examples from Eclipse as indicated on http://www.eclipse.org/swt/examples.php
I followed the steps as prescribed. I followed the link and downloaded the (win32) 3.6 release (timestamp 2010-06-08T09:11).
At step 3, I downloaded the examples repo (org.eclipse.sdk.examples-3.6.zip).
However, when indicating that file as an Archive in Help > Install New Software, the "Work with" field contains "org.eclipse.sdk.examples Repo - jar:file:/D:/data/workspace/source/org.eclipse.sdk.examples- 3.6.zip!/ " but there is no feature to select. The Next and Finish buttons remain disabled.
I don't succeed in doing exactly what the paragraph on installing the examples at http:// download.eclipse.org/eclipse/downloads/drops/R-3.6-201006080 911/details.php#ExamplePlugins says. At some point, I should be prompted to restart, which is in itself surprising as with all other plugin installations I've made so far, I had to select features first.
Has anyone ever encountered this problem? Is the step-by-step breakdown correct? Or am I doing something wrong?
Thanks for any inputs.
[Updated on: Wed, 28 July 2010 18:15]
Report message to a moderator
Re: Installing the examples from p2 repository zip [message #549893 is a reply to message #549752] Wed, 28 July 2010 11:41 Go to previous messageGo to next message
Lakshmi ShanmugamFriend
I tried out the steps under "Running the SWT Examples inside Eclipse" in this page -- http://www.eclipse.org/swt/examples.php. In the Install dialog, when I un-check the "group items by category" I can see the features.
HTH,
Lakshmi P Shanmugam
Re: Installing the examples from p2 repository zip [message #550014 is a reply to message #549893] Wed, 28 July 2010 18:14 Go to previous message
Thanks. It worked fine.
Previous Topic:Auto scroll contents of SWT Browser
Next Topic:Widgets in OpenGL view
Current Time: Sat Jun 23 18:21:31 GMT 2018
Powered by FUDForum. Page generated in 0.01575 seconds
