Home » Eclipse Projects » Remote Application Platform (RAP) » Custom Control(Need a div element child of a custom control)
Custom Control [message #549721] Tue, 27 July 2010 17:00 Go to next message
Jesus   Luna Quiroga is currently offline Jesus Luna QuirogaFriend
Member
Hi, I'm creating a custom control wrapping a control from YUI, but this control needs a div element.
<div id="calContainer"></div>
var c = new YAHOO.widget.Calendar("calContainer", configOptions);
I don't know how to create a div that is child of my custom control in qooxdoo, the only way I can create it is with the document object:
document.createElement( "div" );
But this places the control outside the application's frame.
Can you help me creating this div in order to be a child of my custom control?
Re: Custom Control [message #549743 is a reply to message #549721] Tue, 27 July 2010 19:18 Go to previous messageGo to next message
Philipp Eichhorn is currently offline Philipp EichhornFriend
Hi Jesus,
I believe this simple skeleton should do the trick, although there are probably better solutions involving qooxdoo API:
qx.Class.define("custom.widget.dummy", {
    extend: qx.ui.layout.CanvasLayout,
    construct: function(id) {
        this.base(arguments);
        this.setHtmlAttribute("id", id);
        this.__id = id;
    members : {
        load : function () {
            qx.ui.core.Widget.flushGlobalQueues();
            var element = document.getElementById(this.__id);
            // create DIV
            document.createElement("YOUR_DIV");
            // append it as a child
            element.appendChild(document);
Just pass the widget id in your LCA, when creating the widget:
String id = WidgetUtil.getId(widget);
writer.newWidget("custom.widget.dummy", new Object[] { id });
[Updated on: Tue, 27 July 2010 19:23]
Report message to a moderator
Re: Custom Control [message #549747 is a reply to message #549743] Tue, 27 July 2010 19:27 Go to previous messageGo to next message
Thinking about it, if you only want to wrap the calendar, even this would be enough:
var c = new YAHOO.widget.Calendar(element, configOptions);
Re: Custom Control [message #549791 is a reply to message #549721] Tue, 27 July 2010 23:57 Go to previous message
Member
That worked fine, thanks!
Previous Topic:the view turned into blank
Next Topic:Plugin Registry and Error Logs View
Current Time: Mon May 21 22:59:31 GMT 2018
Powered by FUDForum. Page generated in 0.01550 seconds
