Home » Modeling » TMF (Xtext) » params of Mwe2Launcher?
params of Mwe2Launcher? [message #549569] Tue, 27 July 2010 09:04 Go to next message
Cong Kinh NGUYEN is currently offline Cong Kinh NGUYENFriend
Member
Hi everybody,
I'm using xtext 1.0.0, and trying to use command line to execute the module 'generator'. Could you tell me how to give parameters to the class org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher?
Because I see the code of Mwe2Launcher, but I don't understand how to give parameters about moduleName?
Thanks in advance,
Kinh
Re: params of Mwe2Launcher? [message #549575 is a reply to message #549569] Tue, 27 July 2010 09:11 Go to previous messageGo to next message
Member
Not only moduleName, but also 'options'? Because it seems to me that moduleName is org.eclipse.emf.mwe2.language.mwe2.Module?
Kinh
Cong Kinh NGUYEN wrote on Tue, 27 July 2010 05:04
Hi everybody,
Thanks in advance,
Kinh
Re: params of Mwe2Launcher? [message #549636 is a reply to message #549569] Tue, 27 July 2010 12:34 Go to previous message
Member
I understood my problem. In fact, I use Maven to invoke Mwe2Launcher, but I don't define the java.class.path for this class. So, finally, I only add an environment variable 'java.class.path' as following:
<plugin>
<groupId>org.codehaus.mojo</groupId>
<artifactId>exec-maven-plugin</artifactId>
<version>1.1</version>
<configuration><mainClass>org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher </mainClass>
<arguments>
<argument>${basedir}/workflow/CosmosDslGenerator.mwe2</argument >
</arguments>
<systemProperties>
<systemProperty>
<key>java.class.path</key>
<value>${basedir}</value>
</systemProperty>
</systemProperties>
</configuration>
</plugin>
Thank you anyway,
Kinh
Previous Topic:Help with Creating New DSL
Next Topic:two levels of the generated package ?
Current Time: Sat Jan 20 19:10:35 GMT 2018
Powered by FUDForum. Page generated in 0.01633 seconds
