Home » Language IDEs » ServerTools (WTP) » Does eclipse has a feature of auto usage finder on selecting a part of code ?
Does eclipse has a feature of auto usage finder on selecting a part of code ? [message #549463] Mon, 26 July 2010 17:12 Go to next message
Venkattesh B is currently offline Venkattesh BFriend
Hi all,
I am new to eclipse shifted from netbeans. Does eclipse has a feature f auto usage finder on selecting a part of code ?
Say I create a simple java file helloWorld.java.
In that i create and use variable int abc 10 times.
What I want is As soon I click or select the variable abc in the code it other multiple usages should be highlited by some fill color and it should also be shown in side column bar as it does for showing error messages
I dont want to click CTLR+F for doing this.
This feature is there in netbeans.
I hope u understand what I am looking for
Venkat
Re: Does eclipse has a feature of auto usage finder on selecting a part of code ? [message #549481 is a reply to message #549463] Mon, 26 July 2010 19:04 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
On 7/26/2010 11:12 AM, venkat_walking@yahoo.co.in wrote:
> Hi all,
> messages
> Thanks
> Venkat
Something like this. Among other options, if you double-click an
identifier, all other occurrences of it are color-filled highlighted in
the editor and, if your contract/brightness/color settings are adequate
for your monitor, down the right-hand side there will be markers you can
click to go to occurrences.
Re: Does eclipse has a feature of auto usage finder on selecting a part of code ? [message #549485 is a reply to message #549481] Mon, 26 July 2010 19:32 Go to previous message
Thnaks for replying Russell Bateman,
I figured out myself.here what I did may be useful someone else.
http://img839.imageshack.us/img839/8838/eclipsesearch.jpg
In my eclipse that option was not checked hence all other occurrences were not highlighted
Thanks once again
Venkat
[Updated on: Mon, 26 July 2010 19:35]
Report message to a moderator
Previous Topic:log4j.xml not copied to build folder
Next Topic:Localizing tags in html
Current Time: Sat May 26 02:36:12 GMT 2018
Powered by FUDForum. Page generated in 0.01645 seconds
