Home » Eclipse Projects » SWTBot » java.lang.NoClassDefFoundError: junit/framework/TestListener
java.lang.NoClassDefFoundError: junit/framework/TestListener [message #549321] Mon, 26 July 2010 13:13 Go to next message
Marou is currently offline MarouFriend
I start working with Swtbot and all my tests work on eclipse.
When i want to run my testsuite in command line
/prj/spg_sand/haddadm/local/vsctd/bin/vsocstudio -data /prj/spg_sand/haddadm/local/vsctd/bin/result formatter=org.apache.tools.ant.taskdefs.optional.junit.XMLJUnitResultFormatter,/prj/spg_sand/haddadm/local/vsctd/bin/plugins/com.st.testcosimcockpit.alltests.TestNewFlow.xml formatter=org.apache.tools.ant.taskdefs.optional.junit.PlainJUnitResultFormatter -application org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplication -Dtest.eclipse.dir=`/prj/spg_sand/haddadm/local/vsctd/bin/vsocstudio` -testPluginName com.st.testcosimcockpit -className com.st.testcosimcockpit.alltests.TestNewFlow -debug -consolelog
i get this error
Start VM: /sw/st_division/spg/ext_tools/jdk/Linux-i686/jdk1.6.0_17/bin/java
-Xms256m
-Xmx512m
-XX:MaxPermSize=512m
-Dsun.java2d.pmoffscreen=false
-Dorg.osgi.framework.bootdelegation=*
-Dosgi.configuration.cascaded=true
-Dosgi.sharedConfiguration.area=/prj/spg_sand/haddadm/local/vsctd/configuration
-Dosgi.configuration.area=@user.home/.vsocstudio/dp_201007231230
-jar /sw/st_division/spg/st_tools/STWorkbench/4.1.1/Linux-i686/plugins/org.eclipse.equinox.launcher_1.0.102.1.jar
-os linux
-ws gtk
-arch x86
-showsplash
-launcher /sw/st_division/spg/st_tools/STWorkbench/4.1.1/Linux-i686/stworkbench
-name Stworkbench
--launcher.library /sw/st_division/spg/st_tools/STWorkbench/4.1.1/Linux-i686/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_1.0.101.R34x_v20080805/eclipse_1115.so
-startup /sw/st_division/spg/st_tools/STWorkbench/4.1.1/Linux-i686/plugins/org.eclipse.equinox.launcher_1.0.102.1.jar
-exitdata 668005
-Dtest.eclipse.dir=
-debug
-consolelog
-vm /sw/st_division/spg/ext_tools/jdk/Linux-i686/jdk1.6.0_17/bin/java
-vmargs
-Xms256m
-Xmx512m
Configuration location:
    file:/home/haddadm/.vsocstudio/dp_201007231230/
Configuration file:
    file:/home/haddadm/.vsocstudio/dp_201007231230/config.ini loaded
Configuration file:
    file:/prj/spg_sand/haddadm/local/vsctd/configuration/config.ini loaded
Shared configuration location:
Install location:
    file:/sw/st_division/spg/st_tools/STWorkbench/4.1.1/Linux-i686/
Framework located:
    file:/sw/st_division/spg/st_tools/STWorkbench/4.1.1/Linux-i686/plugins/org.eclipse.osgi_3.4.3.R34x_v20081215-1030.jar
Framework classpath:
Splash location:
    /sw/st_division/spg/st_tools/STWorkbench/4.1.1/Linux-i686/plugins/com.st.platform_4.1.1.0/splash.bmp
Debug options:
    file:/prj/spg_sand/haddadm/.options not found
Time to load bundles: 11
Starting application: 1336
!SESSION 2010-07-26 15:07:54.250 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_17
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Framework arguments:  formatter=org.apache.tools.ant.taskdefs.optional.junit.XMLJUnitResultFormatter,/prj/spg_sand/haddadm/local/vsctd/bin/plugins/com.st.testcosimcockpit.alltests.TestNewFlow.xml formatter=org.apache.tools.ant.taskdefs.optional.junit.PlainJUnitResultFormatter -application org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplication -Dtest.eclipse.dir= -testPluginName com.st.testcosimcockpit -className com.st.testcosimcockpit.alltests.TestNewFlow
Command-line arguments:  -os linux -ws gtk -arch x86 -data /prj/spg_sand/haddadm/local/vsctd/bin/result formatter=org.apache.tools.ant.taskdefs.optional.junit.XMLJUnitResultFormatter,/prj/spg_sand/haddadm/local/vsctd/bin/plugins/com.st.testcosimcockpit.alltests.TestNewFlow.xml formatter=org.apache.tools.ant.taskdefs.optional.junit.PlainJUnitResultFormatter -application org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplication -Dtest.eclipse.dir= -testPluginName com.st.testcosimcockpit -className com.st.testcosimcockpit.alltests.TestNewFlow -debug -consolelog
!ENTRY org.eclipse.ui.workbench 2 0 2010-07-26 15:08:00.103
!MESSAGE A handler conflict occurred.  This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2010-07-26 15:08:00.103
!MESSAGE Conflict for 'AUTOGEN:::org.eclipse.cdt.debug.ui.FunctionBreakpointActions/org.eclipse.cdt.debug.internal.ui.actions.ManageFunctionBreakpointActionDelegate':
HandlerActivation(commandId=AUTOGEN:::org.eclipse.cdt.debug.ui.FunctionBreakpointActions/org.eclipse.cdt.debug.internal.ui.actions.ManageFunctionBreakpointActionDelegate,
        handler=ActionDelegateHandlerProxy(null,org.eclipse.cdt.debug.internal.ui.actions.ManageFunctionBreakpointActionDelegate),
        expression=WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@1041876),sourcePriority=16384)
!MESSAGE Conflict for 'AUTOGEN:::com.st.cosimcockpit.contribution1/com.st.cosimcockpit.newAction':
HandlerActivation(commandId=AUTOGEN:::com.st.cosimcockpit.contribution1/com.st.cosimcockpit.newAction,
        handler=ActionDelegateHandlerProxy(null,com.st.cosimcockpit.popup.actions.Netlist),
        handler=ActionDelegateHandlerProxy(null,com.st.cosimcockpit.popup.actions.SpiritCheck),
Application Started: 5973
Exception in thread "WorkbenchTestable" java.lang.NoClassDefFoundError: junit/framework/TestListener
        at java.lang.ClassLoader.defineClass1(Native Method)
        at java.lang.ClassLoader.defineClass(ClassLoader.java:616)
        at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass(DefaultClassLoader.java:165)
        at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:554)
        at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:524)
        at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager.java:455)
        at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass_LockClassLoader(ClasspathManager.java:443)
        at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:423)
        at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:193)
        at org.eclipse.osgi.framework.internal.core.BundleLoader.findLocalClass(BundleLoader.java:370)
        at org.eclipse.osgi.framework.internal.core.BundleLoader.findClassInternal(BundleLoader.java:446)
        at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:399)
        at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:387)
        at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:87)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
        at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:316)
        at org.eclipse.osgi.framework.internal.core.SingleSourcePackage.loadClass(SingleSourcePackage.java:33)
        at org.eclipse.osgi.framework.internal.core.BundleLoader.findClassInternal(BundleLoader.java:434)
        at org.eclipse.swtbot.eclipse.junit4.headless.EclipseTestRunner.createFormatter(EclipseTestRunner.java:455)
        at org.eclipse.swtbot.eclipse.junit4.headless.EclipseTestRunner.createAndStoreFormatter(EclipseTestRunner.java:437)
        at org.eclipse.swtbot.eclipse.junit4.headless.EclipseTestRunner.run(EclipseTestRunner.java:179)
        at org.eclipse.swtbot.eclipse.junit4.headless.UITestApplication.runTests(UITestApplication.java:115)
        at org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(Unknown Source)
        at java.lang.Thread.run(Thread.java:619)
Caused by: java.lang.ClassNotFoundException: junit.framework.TestListener
        at org.eclipse.osgi.framework.internal.core.BundleLoader.findClassInternal(BundleLoader.java:483)
        ... 38 more
I think that the problem comes from
because when i run the command without formatter every thing is ok but i dont find the result of tests
I work whith eclipse Version: 3.4.2 and Junit 4
Thank You in advance
Re: java.lang.NoClassDefFoundError: junit/framework/TestListener [message #549396 is a reply to message #549321] Mon, 26 July 2010 14:49 Go to previous messageGo to next message
Ketan Padegaonkar is currently offline Ketan PadegaonkarFriend
It appears that some dependencies are not met. Can you verify that you
have all the following dependencies required to run SWTBot in headless
mode as described here:
http://wiki.eclipse.org/SWTBot/Ant#Pre-requisites
Also this error is at times caused because you have
org.eclipse.ant.optional fragment in your plugins directory. Make sure
that you do not have org.eclipse.swtbot.ant.optional.junit3 or
org.eclipse.swtbot.eclipse.junit3.headless in your plugins dir.
Ketan
http://ketan.padegaonkar.name | http://eclipse.org/swtbot
On 7/26/10 6:14 AM, Marou wrote:
> formatter=org.apache.tools.ant.taskdefs.optional.junit.XMLJU nitResultFormatter,/prj/spg_sand/haddadm/local/vsctd/bin/plu gins/com.st.testcosimcockpit.alltests.TestNewFlow.xml
> formatter=org.apache.tools.ant.taskdefs.optional.junit.Plain JUnitResultFormatter
> -application
> org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplica tion
> -Dtest.eclipse.dir=`/prj/spg_sand/haddadm/local/vsctd/bin/vs ocstudio`
> i get this error
> Start VM: /sw/st_division/spg/ext_tools/jdk/Linux-i686/jdk1.6.0_17/bin /java
> -Xms256m
> -Xmx512m
> -Dosgi.sharedConfiguration.area=/prj/spg_sand/haddadm/local/ vsctd/configuration
> -Dosgi.configuration.area=@user.home/.vsocstudio/dp_20100723 1230
> -jar
> /sw/st_division/spg/st_tools/STWorkbench/4.1.1/Linux-i686/pl ugins/org.eclipse.equinox.launcher_1.0.102.1.jar
> -os linux
> -ws gtk
> -arch x86
> -showsplash
> -launcher
> /sw/st_division/spg/st_tools/STWorkbench/4.1.1/Linux-i686/st workbench
> -name Stworkbench
> --launcher.library
> /sw/st_division/spg/st_tools/STWorkbench/4.1.1/Linux-i686/pl ugins/org.eclipse.equinox.launcher.gtk.linux.x86_1.0.101.R34 x_v20080805/eclipse_1115.so
> -startup
> -exitdata 668005
> -application
> -Dtest.eclipse.dir=
> -debug
> -consolelog
> -vm /sw/st_division/spg/ext_tools/jdk/Linux-i686/jdk1.6.0_17/bin /java
> -vmargs
> -Xms256m
> -Xmx512m
> -jar
> Configuration file:
> Configuration file:
> file:/prj/spg_sand/haddadm/local/vsctd/configuration/config. ini loaded
> Install location:
> file:/sw/st_division/spg/st_tools/STWorkbench/4.1.1/Linux-i6 86/
> Framework located:
> file:/sw/st_division/spg/st_tools/STWorkbench/4.1.1/Linux-i6 86/plugins/org.eclipse.osgi_3.4.3.R34x_v20081215-1030.jar
> Splash location:
> /sw/st_division/spg/st_tools/STWorkbench/4.1.1/Linux-i686/pl ugins/com.st.platform_4.1.1.0/splash.bmp
> Debug options:
> -application
> -application
> 'AUTOGEN:::org.eclipse.cdt.debug.ui.FunctionBreakpointAction s/org.eclipse.cdt.debug.internal.ui.actions.ManageFunctionBr eakpointActionDelegate':
> HandlerActivation(commandId=AUTOGEN:::org.eclipse.cdt.debug. ui.FunctionBreakpointActions/org.eclipse.cdt.debug.internal. ui.actions.ManageFunctionBreakpointActionDelegate,
> handler=ActionDelegateHandlerProxy(null,org.eclipse.cdt.debu g.internal.ui.actions.ManageFunctionBreakpointActionDelegate ),
> 'AUTOGEN:::com.st.cosimcockpit.contribution1/com.st.cosimcoc kpit.newAction':
> HandlerActivation(commandId=AUTOGEN:::com.st.cosimcockpit.co ntribution1/com.st.cosimcockpit.newAction,
> handler=ActionDelegateHandlerProxy(null,com.st.cosimcockpit. popup.actions.Netlist),
> handler=ActionDelegateHandlerProxy(null,com.st.cosimcockpit. popup.actions.SpiritCheck),
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:165)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:554)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:524)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:455)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass_LockClassLoader(ClasspathManager.java:443)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:423)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:370)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:446)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:399)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:387)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
> at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:316 )
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:33)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:434)
> at
> at
> at
> at
> org.eclipse.swtbot.eclipse.junit4.headless.EclipseTestRunner .createFormatter(EclipseTestRunner.java:455)
> at
> org.eclipse.swtbot.eclipse.junit4.headless.EclipseTestRunner .createAndStoreFormatter(EclipseTestRunner.java:437)
> at
> org.eclipse.swtbot.eclipse.junit4.headless.EclipseTestRunner .run(EclipseTestRunner.java:179)
> at
> org.eclipse.swtbot.eclipse.junit4.headless.UITestApplication .runTests(UITestApplication.java:115)
> at org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(Unkn own Source)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:483)
> at
> at
> at
> ... 38 more
Re: java.lang.NoClassDefFoundError: junit/framework/TestListener [message #549498 is a reply to message #549321] Mon, 26 July 2010 21:08 Go to previous messageGo to next message
Hi Ketan ,
Thank you for the answer,
Every thing is like http://wiki.eclipse.org/SWTBot/Ant#Pre-requisites
but i still have this Exception
when i run without formatter, the execution of swt classes is fine but without generating result of junit_test
Any other ideas?
[Updated on: Mon, 26 July 2010 21:09]
Report message to a moderator
Re: java.lang.NoClassDefFoundError: junit/framework/TestListener [message #549842 is a reply to message #549321] Wed, 28 July 2010 08:21 Go to previous messageGo to next message
The problem comes from my environment and configuration of eclipse and SWTBot and my extension location.
Every thing is OK.
Thank you.
Re: java.lang.NoClassDefFoundError: junit/framework/TestListener [message #633303 is a reply to message #549842] Sat, 16 October 2010 06:59 Go to previous message
Ravi  is currently offline Ravi Friend
I am also facing the same problem. What configurations, settings etc you have changed to overcome this problem?
Thanks in Advance
Ravi
Previous Topic:Failed to start test application with "Application Error" message
Next Topic:formatter option does not allow test cases to run
Current Time: Wed May 23 22:57:50 GMT 2018
Powered by FUDForum. Page generated in 0.02098 seconds
