Home » Eclipse Projects » Platform - User Assistance (UA) » The reference to entity "id" must end with the ';' delimiter. Bug?(The reference to entity "id" must end with the ';' delimiter. Bug?)
The reference to entity "id" must end with the ';' delimiter. Bug? [message #549195] Mon, 26 July 2010 03:49 Go to next message
Ole Ersoy is currently offline Ole ErsoyFriend
I'm writing some documentation that includes a link to an infocenter bug. When I open the page in firefox, it displays fine and the link works fine. However when attempting to load the page in the infocenter I get the following error:
It's because of the doctype used. If I delete the doctype declaration the infocenter loads the page fine. Just wondering if this is a bug?
The page looks like this:
<!DOCTYPE   html PUBLIC "-//W3C//DTD XHTML 1.1 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html>
<head>
	<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1"></meta>
	<link rel="stylesheet" href="../../book.css" charset="ISO-8859-1" type="text/css"></link>
	<title>Including MathML</title>
</head>
<body>
<h1>Including MathML</h1>
<p>
See:
<a href="https://bugs.eclipse.org/bugs/show_bug.cgi?format=multiple&id=317215">Help content containing MathML is not rendered correctly in Infocenter</a>.
 </p>
</body>
</html>
Thoughts?
TIA,
- Ole
Re: The reference to entity "id" must end with the ';' delimiter. Bug? [message #550304 is a reply to message #549195] Thu, 29 July 2010 20:42 Go to previous messageGo to next message
Chris Goldthorpe is currently offline Chris GoldthorpeFriend
It does look like a bug. Documents with a doctype of xhtml get preprocessed by the help system to support inclusion and replacement of content.
The workaround is to use an HTML doctype but in the meantime can you file a bug also?
Re: The reference to entity "id" must end with the ';' delimiter. Bug? [message #550339 is a reply to message #550304] Fri, 30 July 2010 00:03 Go to previous messageGo to next message
OK - It's been filed.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=321279
Please let me know if there's anything else that would be helpful.
- Ole
Re: The reference to entity "id" must end with the ';' delimiter. Bug? [message #550545 is a reply to message #550304] Fri, 30 July 2010 18:36 Go to previous message
Pierre Candela is currently offline Pierre CandelaFriend
> content.
> file a bug also?
I don't think it's a bug. The '&' character in the bugzilla url
should've been escaped, ie:
https://bugs.eclipse.org/bugs/show_bug.cgi?format=multiple&a mp;amp;id=317215
Pierre
Previous Topic:Defining a search scope using criteria
Next Topic:Infocenter and command support
Current Time: Thu Jan 18 22:05:52 GMT 2018
Powered by FUDForum. Page generated in 0.01524 seconds
