Home » Archived » IAM (Eclipse Integration for Apache Maven) » Creating Maven projects(Installation problems with Maven and Wicket plugins for Eclipse)
Creating Maven projects [message #549157] Sun, 25 July 2010 13:49 Go to next message
Kristian Sejersen is currently offline Kristian SejersenFriend
Hey.
I am currently trying to setup my Eclipse IDE for using Wicket, and thus i want to install Maven in order to make it work. Now from what i understand you need to have Maven in your given Dynamic Web Project in order to add the necesary information for Wicket.
This brings my to what i expect to be a very trivial question. How do i add Maven to a given Dynamic web project ?? Embarrassed
I have already installed the Maven2 plugin for Eclipse.
I must admit i find the whole setup and installation a bit confusing and what i find on google is usually a bounch of command lines i need to run in a unix system, but unfortunately i am running windows.
I am currently reading the "Wicket in action" book, which has a lot of nice examples i'd like to play around with in order to get a better understanding of Wicket.
Best regards
Kristian
Re: Creating Maven projects [message #549854 is a reply to message #549157] Wed, 28 July 2010 08:51 Go to previous message
Carlos Sanchez is currently offline Carlos SanchezFriend
From Eclipse with our Eclipse IAM plugin installed you can do
File - New - Project - Maven 2 Project - Maven 2 Project Creation Wizard
and then find a Wicket archetype to use to create a skeleton Wicket project.
Or from an existing Maven project, right click and select Maven 2 - Use
Maven dependency management
to enable Maven in the Eclipse IDE
On 7/25/10 9:49 PM, Kristian Sejersen wrote:
> Hey.
> add Maven to a given Dynamic web project ?? :blush:
> Best regards
> Kristian
Previous Topic:Creating Maven projects
Next Topic:Unable to open pom from maven container
Current Time: Tue Jan 16 17:55:04 GMT 2018
Powered by FUDForum. Page generated in 0.01453 seconds
