Home » Newcomers » Newcomers » Eclipse.exe will not start after editing eclipse.ini
Eclipse.exe will not start after editing eclipse.ini [message #549071] Sat, 24 July 2010 00:45 Go to next message
Missing name Missing name is currently offline Missing name Missing nameFriend
Hello all! I would just like to start by saying that I am very new to Eclipse. What I want is the Eclipse for PHP Developers. Here is as much information as I can think of (without being overwhelming). If you need more, Please ask me. I really want to solve this. Thanks!
I am running Windows Vista Home Premium 64bit. This is on HP pavillion m9458f.
I began by downloading the eclipse-php-helios-win32-x86_64.zip for Windows 64bit and saving it to my desktop ( http://www.eclipse.org/downloads/download.php?file=/technolo gy/epp/downloads/release/helios/R/eclipse-php-helios-win32-x 86_64.zip&url=http://mirror.csclub.uwaterloo.ca/eclipse/ technology/epp/downloads/release/helios/R/eclipse-php-helios -win32-x86_64.zip&mirror_id=492). I then extracted it by right-clicking and choosing "Extract all..." to C:\Program Files. It automatically created the eclipse folder in that directory.
After getting the error "A Java Runtime Environment (JRE) or Java Development Kit (JDK) must be available in order to run Eclipse. No Java virtual machine was found after searching the following locations...", I discovered that I have to modify my eclipse.ini file to include the following lines (http://wiki.eclipse.org/Eclipse.ini).
-vm
C:\Program Files (x86)\Java\jre6\bin\javaw.exe
Here is what eclipse.ini now looks like:
plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1. 0.v20100503
-product
org.eclipse.epp.package.php.product
--launcher.defaultAction
openFile
--launcher.XXMaxPermSize
256M
-showsplash
org.eclipse.platform
256m
-vm
openFile
-vmargs
-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx384m
The javaw.exe file version is 6.0.200.2 I have also tried linking it to the 6.0.10.7 version included in C:\Program Files (x86)\Java\jre1.6.0_01\bin
The problem: eclipse will not start. There are no error messages since I edited eclipse.ini. If I can provide any more information or if I have forgotten something, please let me know. Thank you!
P.S. I have checked out this page: http://wiki.eclipse.org/FAQ_I_unzipped_Eclipse,_but_it_won't _start._Why%3F and do not think that I have done anything wrong except possible number 2 (bad VM). I don't know if I am using a 32 or 64 bit version of JVM. How can I tell? Thanks!
[Updated on: Sat, 24 July 2010 01:11]
Report message to a moderator
Re: Eclipse.exe will not start after editing eclipse.ini [message #549078 is a reply to message #549071] Sat, 24 July 2010 05:22 Go to previous messageGo to next message
No real name is currently offline No real nameFriend
I had the same problem as you have. You might need to download JRE 64 bit version, assuming you are installing Helios 64bit. Links below has helped me solving the problem. I hope they will help you too. Good luck
https://cds.sun.com/is-bin/INTERSHOP.enfinity/WFS/CDS-CDS_De veloper-Site/en_US/-/USD/ViewFilteredProducts-SingleVariatio nTypeFilter
http://stackoverflow.com/questions/2030434/eclipse-no-java-j re-jdk-no-virtual-machine
http://www.eclipse.org/forums/index.php?t=msg&goto=54294 0&
Re: Eclipse.exe will not start after editing eclipse.ini [message #549123 is a reply to message #549071] Sat, 24 July 2010 21:48 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
> m9458f.
> [snip]
>> -product
>> openFile
>> 256M
>> -showsplash
>> 256m
>> -vm
>> openFile
>> -vmargs
>> -Xms40m
>> -Xmx384m
> [snip]
Note that you must either use Eclipse 32 bit and a 32-bit JDK, or
Eclipse 64=bit and a 64-bit JDK. You can't mix the two worlds. By the
way, a 32-bit set works fine on a 64-bit Windows or Linux. I have so far
resisted moving to using 64-bit (too lazy).
Re: Eclipse.exe will not start after editing eclipse.ini [message #549425 is a reply to message #549123] Mon, 26 July 2010 15:28 Go to previous messageGo to next message
Thank you, both of you. Were you able to tell from the information that I sent that I was using a 32 bit JDK/JRE?
I'm downloading the 32bit eclipse for PHP, and I'll let you know how it goes.
Again, thanks a million for the help. It's really appreciated.
Re: Eclipse.exe will not start after editing eclipse.ini [message #549445 is a reply to message #549425] Mon, 26 July 2010 16:10 Go to previous messageGo to next message
All right, all seems to work! Thank you again!
Now all I have to do is figure out how it works. I thought that I was going to be able to see my PHP web page somewhere like in a browser, but haven't found out how to yet.
Re: Eclipse.exe will not start after editing eclipse.ini [message #549452 is a reply to message #549445] Mon, 26 July 2010 16:46 Go to previous messageGo to next message
Try the PHP (PDT) forum for Eclipse and find a simple tutorial
somewhere. An hour or so of that will probably finish leveling your
obstacles.
Re: Eclipse.exe will not start after editing eclipse.ini [message #549513 is a reply to message #549452] Tue, 27 July 2010 01:37 Go to previous message
OK. Thank you so much, Russell! I figured out that i didn't have Zend installed. I'm learning things, though! Thank you again for your help!
Previous Topic:Problem In Updating RFT 8.1.1 With Existing Eclipse
Next Topic:custom wizard does not appear
Current Time: Wed Feb 21 04:05:35 GMT 2018
Powered by FUDForum. Page generated in 0.03160 seconds
