Unable to load newly created plugins [message #548857] |
Fri, 23 July 2010 10:13 |
Leela  Messages: 10 Registered: June 2010 |
Junior Member |
Hi,.
I am unable to load plugins that are instrumented using Emma.
As classes are referring to emma jar, it was throwing ClassNotFoundException. Hence added emma.jar under runtime folder of each plugin and also added entry in Manifest.mf file under Bundle ClassPath: section.
Now, only few plugins are loaded and other plugins are not able to loaded and throwing exception as
org.osgi.framework.BundleException: The activator com.trapedza.bankfusion.fatomconfig.FatomConfigPlugin for bundle com.trapedza.bankfusion.fatomconfig is invalid
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:962)
Caused by: java.lang.Error: EMMA: runtime controller could not be started, aborting
at com.vladium.emma.rt.RT.reset(RT.java:233)
at com.vladium.emma.rt.RT.<clinit>(RT.java:540)
at com.trapedza.bankfusion.fatomconfig.FatomConfigPlugin.$VRi(F atomConfigPlugin.java)
Can anyone help me on this???
FUDForum. Page generated in 0.01431 seconds
