Home » Language IDEs » C / C++ IDE (CDT) » symbol table // paths
symbol table // paths [message #548808] Fri, 23 July 2010 07:06 Go to next message
Michael Mising name is currently offline Michael Mising nameFriend
HI
while starting debug i get:
Warning: /CPP/PC1;E: No such file or directory.
Warning: E:\CPP\PC1/E: No such file or directory.
No symbol table is loaded. Use the "file" command.
Seems like the paths are mangled. Any way to fix? Settings -> defaults etc. nothing works
[Updated on: Fri, 23 July 2010 07:06]
Report message to a moderator
Re: symbol table // paths [message #549087 is a reply to message #548808] Sat, 24 July 2010 08:27 Go to previous messageGo to next message
Error in final launch sequence
Failed to execute MI command:
-gdb-set auto-solib-add on
Error message from debugger back end:
Re: symbol table // paths [message #549090 is a reply to message #549087] Sat, 24 July 2010 08:59 Go to previous messageGo to next message
Installed a new mingw and set path now I get for compiling:
(Cannot run program "make": Launching failed)
Re: symbol table // paths [message #549138 is a reply to message #549090] Sun, 25 July 2010 07:28 Go to previous message
Solved make by copying/renaming. Also I seem to have 64bit gdb instead of the 32bit version.
[Updated on: Sun, 25 July 2010 09:32]
Previous Topic:c/c++ index rebuild
Next Topic:Override methods, imlement functions.
Current Time: Sat Apr 21 15:37:02 GMT 2018
Powered by FUDForum. Page generated in 0.02171 seconds
