Home » Newcomers » Newcomers » Trouble: AVR Eclipse Plugin + SimulAVR  () 1 Vote
Trouble: AVR Eclipse Plugin + SimulAVR [message #548541] Thu, 22 July 2010 09:58 Go to next message
No real name is currently offline No real nameFriend
I used this manual - http://avr-eclipse.sourceforge.net/wiki/index.php/Debugging for connect SimulAVR (from WinAVR) with AVR Eclipse Plugin.
When I start debug-mode I got such message
http://imglink.ru/thumbnails/22-07-10/7a701e3d587c28935e843d26b8600a49.jpg
Can you help me solve this problem? Please
P.S.: and do I need create .gdbinit file? Maybe trouble there
[Updated on: Thu, 22 July 2010 10:03]
Report message to a moderator
Re: Trouble: AVR Eclipse Plugin + SimulAVR [message #548643 is a reply to message #548541] Thu, 22 July 2010 14:15 Go to previous message
Russell Bateman is currently offline Russell BatemanFriend
This is not the right forum. You should try either the PDT form:
http://www.eclipse.org/forums/index.php?t=thread&frm_id= 85&
or the CDT forum:
http://www.eclipse.org/forums/index.php?t=thread&frm_id= 80&
(Note: I could be grossly mistaken about this, however, I'm not mistaken
about the next bit:)
..gdbinit is only a place for you to create some short-hand for orienting
your gdb debugging session, setting up breakpoints you know you always
want, and other things. It is not actually necessary to the running of gdb.
Hope this helps,
Russ Bateman
Previous Topic:Android and flex just can't get along
Next Topic:Re: Build problem
Current Time: Mon Jan 22 06:33:05 GMT 2018
Powered by FUDForum. Page generated in 0.02475 seconds
