Home » Eclipse Projects » Eclipse Platform » Build problem(Building Eclipse 3.5.2 on FreeBSD 7)
Build problem [message #548428] Wed, 21 July 2010 19:10
No real name is currently offline No real nameFriend
Howdy, I'm attempting to build Eclipse 3.5.2 on FreeBSD 7 from ports, and it's giving me this frustrating error:
BUILD FAILED
/usr/ports/java/eclipse/work/eclipse-build-0.5.0/build.xml:88: The following error occurred while executing this line:
/usr/ports/java/eclipse/work/eclipse-build-0.5.0/pdebuild.xml:162: The following error occurred while executing this line:
/usr/ports/java/eclipse/work/eclipse-build-0.5.0/build/eclipse-3.5.2-src/plugins/org.eclipse.equinox.registry/build.xml:165: The following error occurred while executing this line:
/usr/ports/java/eclipse/work/eclipse-build-0.5.0/build/eclipse-3.5.2-src/plugins/org.eclipse.equinox.registry/build.xml:126: javac doesn't support the "errorProperty" attribute
Total time: 1 second
*** Error code 1
Stop in /usr/ports/java/eclipse.
*** Error code 1
My JVM is diablo-jdk-1.6.0.07.02_9, if that's relevant. Do I need to just fly through all of the build.xml files it errors on and remove the errorProperty portion, or is there a more elegant solution?
Thanks for your time.
[Updated on: Wed, 21 July 2010 19:11]
Report message to a moderator
Previous Topic:How to set space between TableViewer and (parent) Composite?
Next Topic:Disable scrolling in MasterDetailsBlock
Current Time: Wed Jun 20 08:02:35 GMT 2018
Powered by FUDForum. Page generated in 0.02168 seconds
