Home » Newcomers » Newcomers » making eclipse follow the java_home variable
making eclipse follow the java_home variable [message #548226] Wed, 21 July 2010 07:46 Go to next message
No real name is currently offline No real nameFriend
I get a warning message when starting eclipse
Eclipse is running in a JRE, but a JDK is required
Some Maven plugins may not work when importing projects or updating source folders.
I could set the -vm path in the eclipse.ini file to just point to the correct JDK, however I am preparing a package that will be used by several persons on different computers.
Thus I would like to set -vm to follow the JAVA_HOME environment varible instead. How do I do this?
Re: making eclipse follow the java_home variable [message #548352 is a reply to message #548226] Wed, 21 July 2010 14:16 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric RizzoFriend
> source folders.
You can't; this bug has a request for it:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=94087
The good news is that you can include the JDK in the package that you're
preparing. If you create a directory <eclipse-home>/jre and put the JDK
in there, Eclipse will use that by default.
Hope this helps,
Eric
Re: making eclipse follow the java_home variable [message #548781 is a reply to message #548226] Thu, 22 July 2010 23:58 Go to previous messageGo to next message
Nilesh is currently offline NileshFriend
this may be unrelated, but instead of sticking the JDK into a directory named JRE, i just changed my JRE installed directory location to point to my JDK, and it worked.
Re: making eclipse follow the java_home variable [message #549355 is a reply to message #548226] Mon, 26 July 2010 14:01 Go to previous message
I solved it with a batch script that changes the line after -vm to the value of the java_home variable, seems to have worked so far.
Previous Topic:Eclipse Helios and XP professional
Next Topic:Topics disappear
Current Time: Thu Apr 19 23:05:10 GMT 2018
Powered by FUDForum. Page generated in 0.02919 seconds
