Home » Eclipse Projects » Plugin Development Environment (PDE) » PDEBuild Missing host org.eclipse.equinox.launcher_[1.0.0,1.2.0)(Error while launching eclipse.exe)
PDEBuild Missing host org.eclipse.equinox.launcher_[1.0.0,1.2.0) [message #547745] Mon, 19 July 2010 14:16 Go to next message
Chris  is currently offline Chris Friend
I use PDEBuild on Helios. My target is Equinox SDK 3.6 with delta pack Equinox 3.6.
The PDEBuild of my product is successfull, but the generated product does not work.
It seems that the org.eclipse.equinox.launcher plugin is missing... however this plugin does exist in plugins directory as org.eclipse.equinox.launcher_1.1.0.v20100507.jar. And its version number matches [1.0.0,1.2.0)... I do not understand !!!
Any help ?
Thanks.
Here is the content of config.ini :
#Product Runtime Configuration File
osgi.bundles.defaultStartLevel=4
osgi.bundles=org.eclipse.equinox.lau[FONT=Arial][/FONT]ncher.win32.win32.x86,org.eclipse.equinox.app@,org.eclipse.equinox.cm@,org.eclipse.equinox.common@,org.eclipse.equinox.concurrent@,org.eclipse.equinox.ds@,org.eclipse.equinox.util@,org.eclipse.osgi.services@,org.eclipse.osgi.util@,org.eclipse.equinox.registry@
And the content of log file with the error :
!SESSION 2010-07-19 16:04:18.296 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_13
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=fr_FR
Command-line arguments:  -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 2 0 2010-07-19 16:04:19.015
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-07-19 16:04:19.015
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.0.v20100503/ was not resolved.
!SUBENTRY 2 org.eclipse.equinox.launcher.win32.win32.x86 2 0 2010-07-19 16:04:19.015
!MESSAGE Missing host org.eclipse.equinox.launcher_[1.0.0,1.2.0).
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!MESSAGE Bundle org.eclipse.equinox.launcher.win32.win32.x86_1.1.0.v20100503 [2] was not resolved.
Re: PDEBuild Missing host org.eclipse.equinox.launcher_[1.0.0,1.2.0) [message #547827 is a reply to message #547745] Mon, 19 July 2010 17:25 Go to previous messageGo to next message
Andrew Niefer is currently offline Andrew NieferFriend
You probably have a configuration problem. This warning message by itself
does not prevent anything from running.
You are getting the message because org.eclipse.equinox.launcher is not on
the osgi.bundles list and the win32.win32.x86 fragment is. However, this
does not prevent eclipse from running because the launcher runs as regular
java because it starts the OSGi framework, it does not need to be resolved
as an osgi bundle.
Chris wrote:
> Equinox 3.6. The PDEBuild of my product is successfull, but the generated
> product does not work. It seems that the org.eclipse.equinox.launcher
> number matches ncher.win32.win32.x86,org.eclipse.equinox.app@,org.eclipse.e quinox.cm@,org.eclipse.equinox.common@,org.eclipse.equinox.c oncurrent@,org.eclipse.equinox.ds@,org.eclipse.equinox.util@ ,org.eclipse.osgi.services@,org.eclipse.osgi.util@,org.eclip se.equinox.registry@
> ----------------------------------------------- eclipse.buildId=unknown
> constraints are not resolved: !SUBENTRY 1 org.eclipse.osgi 2 0 2010-07-19
> 16:04:19.015 !MESSAGE Bundle
initial@reference :file:plugins/org.eclipse.equinox.launcher.win32.win32.x86_1 .1.0.v20100503/
> was not resolved. !SUBENTRY 2 org.eclipse.equinox.launcher.win32.win32.x86
> 2 0 2010-07-19 16:04:19.015 !MESSAGE Missing host
> !SUBENTRY 1 org.eclipse.osgi 2 0 2010-07-19 16:04:19.015 !MESSAGE Bundle
> resolved. !SUBENTRY 2 org.eclipse.equinox.launcher.win32.win32.x86 2 0
Re: PDEBuild Missing host org.eclipse.equinox.launcher_[1.0.0,1.2.0) [message #547891 is a reply to message #547745] Tue, 20 July 2010 06:33 Go to previous message
I resolved the problem !
It seems to be a bug.
The problem that the exec had not the same name than the .ini file. I had : eclipse.ini with launcher.exe.
XXX.exe tries to read XXX.ini file !!!
I did not fill the launcher name field in the product definition. It seems to be a bug in PDEBuild...
When I fill this field, .ini file and .exe file have the same name and it is ok.
Have a good day.
Previous Topic:headless pde build : InvocationTargetException in generated build.xml
Next Topic:PDEBuild Missing host org.eclipse.equinox.launcher_[1.0.0,1.2.0)
Current Time: Wed May 23 17:09:38 GMT 2018
Powered by FUDForum. Page generated in 0.02261 seconds
