Home » Eclipse Projects » Eclipse Platform » How to add submenu using extension "org.eclipse.ui.menus"?
How to add submenu using extension "org.eclipse.ui.menus"? [message #547593] Mon, 19 July 2010 06:30 Go to next message
popjxc is currently offline popjxcFriend
Member
Hi, all:
I want to add a submenu of "Run as" in the "ProjectExplorer".
The followings can add item to the root of popupmenu:
<extension
point="org.eclipse.ui.menus">
<menuContribution locationURI=" popup:org.eclipse.ui.navigator.ProjectExplorer#PopupMenu?aft er=additions ">
<dynamic
class="kaitone.wisp.kul.debug.ui.DynamicRunMenu"
id="kaitone.wisp.kul.debug.ui.DynamicRunMenu1">
</dynamic>
</menuContribution>
</extension>
If I write it like :locationURI=" popup:org.eclipse.ui.navigator.ProjectExplorer#PopupMenu?aft er=run "
or:
locationURI=" popup:org.eclipse.ui.navigator.ProjectExplorer#PopupMenu?aft er=org.eclipse.debug.ui.contextualLaunch.run.submenu "
it does not work...
so how I write the locationURI?
Thanks and Best Regards!
Re: How to add submenu using extension "org.eclipse.ui.menus"? [message #547738 is a reply to message #547593] Mon, 19 July 2010 14:08 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
RunAs comes from popupMenus. org.eclipse.ui.menus can't see popupMenus,
but popupMenus contributions can see org.eclipse.ui.menus contributions.
Maybe if you use org.eclipse.ui.menus to define the Run As menu in the
same way it is defined by the objectContributions ....
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: How to add submenu using extension "org.eclipse.ui.menus"? [message #548224 is a reply to message #547738] Wed, 21 July 2010 07:40 Go to previous message
Member
Paul Webster wrote on Mon, 19 July 2010 10:08
I know where the problem is, maybe I should change another way to do that. I define all the possible menus as "launchShortcut", and for every "launchShortcut" I define a "PropertyTest" to enable or disable the menu item. Luckily there are not so many menu items in my situation.
Thank you very much~
Previous Topic:Eclipse HELIOS
Next Topic:core tools does not work with eclipse 3.6
Current Time: Wed May 23 07:28:35 GMT 2018
Powered by FUDForum. Page generated in 0.01957 seconds
