Home » Eclipse Projects » JavaServer Faces » Tag attributes CA in XHTML files for non-standard taglibs
Tag attributes CA in XHTML files for non-standard taglibs [message #547478] Sat, 17 July 2010 13:16 Go to next message
Vadim Dmitriev is currently offline Vadim DmitrievFriend
Member
Hi.
Eclipse JEE 3.6, new workspace, new dynamic web project, installed JSF
2.0 facet, added openfaces jars to the build path.
Created new test.xhtml with "Facelet Composition Template", added
"http://openfaces.org" namespace ("o" shortname).
CA do list openfaces tags when it is invoked at "<o:| ", however tag
attributes are not listed when CA is invoked at "<o:dataTable |
></o:dataTable>".
Attributes are listed if I rename test.xhtml to test.jspx.
Is this a bug or such functionality for xhtml files is not yet supported?
Re: Tag attributes CA in XHTML files for non-standard taglibs [message #547499 is a reply to message #547478] Sat, 17 July 2010 18:53 Go to previous message
Yury Kats is currently offline Yury KatsFriend
On 7/17/2010 9:16 AM, Vadim Dmitriev wrote:
> Hi.
> ></o:dataTable>".
https://bugs.eclipse.org/bugs/show_bug.cgi?id=315892
Library authors do not bother listing attributes in the facelet taglib (it's not required),
therefore WTP JSF tooling does not know what attributes are available.
In a JSP, attributes are known because library authors have to list them in the TLD file.
Re: Tag attributes CA in XHTML files for non-standard taglibs [message #621841 is a reply to message #547478] Sat, 17 July 2010 18:53 Go to previous message
> Hi.
> ></o:dataTable>".
Previous Topic:Tag attributes CA in XHTML files for non-standard taglibs
Next Topic:Content Assist for Annotaded ManagedBeans
Current Time: Fri May 25 20:23:07 GMT 2018
Powered by FUDForum. Page generated in 0.01997 seconds
