Home » Modeling » TMF (Xtext) » HighlightReconciler doesn't highlight
HighlightReconciler doesn't highlight [message #546985] Wed, 14 July 2010 20:22 Go to next message
Timotei D is currently offline Timotei DFriend
Member
Hi!
I have an instance of "HighlightReconciler".
I use this:
HighlightingReconciler reconcilier = editor.getHighlightingHelper().getReconciler();
reconcilier.addPosition(correspondingTag.getOffset(), correspondingTag.getLength(),	WMLHighlightingConfiguration.RULE_START_END_TAG);
But the highlighting doesn't work. Any sugesstions?
I've checked the offset and it's ok.
Timotei
Re: HighlightReconciler doesn't highlight [message #547034 is a reply to message #546985] Thu, 15 July 2010 06:38 Go to previous messageGo to next message
Alexander Nittka is currently offline Alexander NittkaFriend
I don't know if this approach is going to work. As far as I know, the
reconciler is triggered only on a model change, i.e. not if merely the
cursor position changes.
Have you looked at the code that does the "boxing" the single character?
Maybe you can implement something similar for multiple characters.
Another hack would be to use the editors "reveal" method. Of course the
highlighting of the revealed area will be different from what you want.
Alex
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext@itemis.de
Re: HighlightReconciler doesn't highlight [message #547065 is a reply to message #546985] Thu, 15 July 2010 12:17 Go to previous messageGo to next message
Member
The part with MatchingCharacterPainter doesn't work, as only 1 character can pe paint.
Re: HighlightReconciler doesn't highlight [message #547079 is a reply to message #547065] Thu, 15 July 2010 12:54 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Timotei,
did you try to call highlighting reconciler.refresh() to trigger the
reconciler?
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 15.07.10 14:18, schrieb Timotei:
> can pe paint.
Re: HighlightReconciler doesn't highlight [message #547445 is a reply to message #546985] Fri, 16 July 2010 20:33 Go to previous messageGo to next message
Member
Hi!
Nice, it works with .refresh(). However there is an issue: In my ISemanticHighlight, I've put some higlightings. And that override some of the highlighted previously area. Is any way I can... detect if I highlighted that portion before, and skip it in my ISemantic? Or better, how I clear my position list?
Timotei
Re: HighlightReconciler doesn't highlight [message #547467 is a reply to message #546985] Sat, 17 July 2010 07:26 Go to previous messageGo to next message
Member
So, basically i have the following:
[tohigh]
With my custom bracket matching I highlight: [tohigh]
But, my ISemanticHighlighter higlights this: tohigh
So, in the end it looks like:
[tohigh]
Basically I need a way to know if I should/or not use the SemanticHighlighter. One way I was thinking, can I extend the AbstractNode with a "better" class, and use that, instead of AbstractNode, in my xtext editor/other stuff? I would put another property, and based on that I would hihglight/or not with my SemanticHighlgihter.
Timo
Re: HighlightReconciler doesn't highlight [message #547468 is a reply to message #546985] Sat, 17 July 2010 08:40 Go to previous messageGo to next message
Member
I tried the following:
public class EnhacedLeafNode extends LeafNodeImpl
and then, in MYDSLUiModule.java:
	public Class<? extends LeafNodeImpl> bindLeafNode()
		return EnhacedLeafNode.class;
But that doesn't work, I get exceptions when the editor triies to be instantiated.
UPDATE:
I've tried another route to do this, with this:
	public Class<? extends MergingHighlightedPositionAcceptor> bindMergingHighlightedPositionAcceptor()
		return WMLMergingHighlightedPositionAcceptor.class;
But it neither works.
Do I miss something? It looks like guice can't "override" used classes, only Interfaces?
Timo
[Updated on: Sat, 17 July 2010 10:17]
Report message to a moderator
Re: HighlightReconciler doesn't highlight [message #548312 is a reply to message #547468] Wed, 21 July 2010 12:52 Go to previous messageGo to next message
Hi Timotei,
it is not possible to change the implementation class of the node model.
However, you are free to attach information via leafNode.eAdapters().add(..)
Sebastian
Am 17.07.10 10:40, schrieb Timotei:
> instantiated.
Re: HighlightReconciler doesn't highlight [message #548315 is a reply to message #546985] Wed, 21 July 2010 13:07 Go to previous message
Member
Thanks Sebastian.
That worked.
Timotei
Previous Topic:Generate xtext grammar from xtext grammar
Next Topic:Cross Reference within different classes
Current Time: Thu Jan 18 19:52:27 GMT 2018
Powered by FUDForum. Page generated in 0.02143 seconds
