Home » Newcomers » Newcomers » Eclipse SVN ERROR - The Class File Viewer cannot handle the given input(I can't open and edit the php files from SVN Repository)
icon2.gif  Eclipse SVN ERROR - The Class File Viewer cannot handle the given input [message #546818] Wed, 14 July 2010 10:28 Go to next message
KOmaSHOOTER  is currently offline KOmaSHOOTER Friend
I can not open my php Files from my SVN Repository with eclipse (Eclipse for PHP Developers - eclipse-php-helios-win32).
I also installed Subclipse for eclipse from http://subclipse.tigris.org/servlets/...
What is missing?
The Error Message:
"Could not open the editor: The Class File Viewer cannot handle the given input ..."
Video: http://www.youtube.com/watch?v=DX7dbOyTUfc
http://www.youtube.com/watch?v=KTp0xH-LVQQ
org.eclipse.core.runtime.CoreException: The Class File Viewer cannot handle the given input ('org.tigris.subversion.subclipse.ui.editor.RemoteFileEditorInput').
	at org.eclipse.jdt.internal.ui.javaeditor.ClassFileEditor.doSetInput(ClassFileEditor.java:646)
	at org.eclipse.ui.texteditor.AbstractTextEditor$19.run(AbstractTextEditor.java:3037)
	at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
	at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
	at org.eclipse.jface.window.ApplicationWindow$1.run(ApplicationWindow.java:759)
	at org.eclipse.jface.window.ApplicationWindow.run(ApplicationWindow.java:756)
	at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow.java:2600)
	at org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(AbstractTextEditor.java:3055)
	at org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTextEditor.java:3082)
	at org.eclipse.ui.internal.EditorManager.createSite(EditorManager.java:798)
	at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:647)
	at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
	at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
	at org.eclipse.ui.internal.EditorReference.getEditor(EditorReference.java:289)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2863)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2768)
	at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2760)
	at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2711)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2707)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2691)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2674)
	at org.tigris.subversion.subclipse.ui.actions.OpenRemoteFileAction$1.run(OpenRemoteFileAction.java:66)
	at org.tigris.subversion.subclipse.ui.repository.RepositoryManager.run(RepositoryManager.java:375)
	at org.tigris.subversion.subclipse.ui.actions.SVNAction$1.run(SVNAction.java:231)
	at org.tigris.subversion.subclipse.ui.actions.SVNAction$2.run(SVNAction.java:240)
	at org.tigris.subversion.subclipse.ui.actions.SVNAction.run(SVNAction.java:237)
	at org.tigris.subversion.subclipse.ui.actions.OpenRemoteFileAction.execute(OpenRemoteFileAction.java:39)
	at org.tigris.subversion.subclipse.ui.actions.SVNAction.run(SVNAction.java:56)
	at org.eclipse.ui.actions.ActionDelegate.runWithEvent(ActionDelegate.java:70)
	at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:241)
	at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
	at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
	at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2629)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2593)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2427)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:663)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
[Updated on: Wed, 14 July 2010 14:59]
Report message to a moderator
Re: Eclipse SVN ERROR - The Class File Viewer cannot handle the given input [message #546912 is a reply to message #546818] Wed, 14 July 2010 15:10 Go to previous message
If I choose in the Project Menu
Team -> Share Project...
I can commit and update my files with my SVN Repository.
Tutorial Link: http://jars.de/java/svn-repository-fur-eclipse-projekte-anle gen
But why can I not directly open the php files from the SVN Repository???
When i click on a txt file inside the SVN Repository a menu pops up and ask me wich application I will choose for opening.
[Updated on: Wed, 14 July 2010 15:17]
Previous Topic:can you create an operation to execute when an existing button is clicked
Next Topic:Helios freeze
Current Time: Mon May 21 17:13:04 GMT 2018
Powered by FUDForum. Page generated in 0.02856 seconds
