Home » Eclipse Projects » Equinox » Where to put my java.policy?
Where to put my java.policy? [message #546602] Tue, 13 July 2010 14:15 Go to next message
Mike Rumpf is currently offline Mike RumpfFriend
Member
Hallo,
another question: In our OSGi application we are doing a lot of RMI. Therefore a java.policy file is needed for the security manager.
At the moment this file needs to be placed alongside the exe (after an product export) via the vm argument
-Djava.security.policy=java.policy
I would like to have the policy file inside one of my bundles. How can I achieve that?
Mike
Re: Where to put my java.policy? [message #546684 is a reply to message #546602] Tue, 13 July 2010 18:12 Go to previous message
Thomas Watson is currently offline Thomas WatsonFriend
The java.policy property is expecting a path to a file which can be read very early in the VM startup. I don't see how you could reference a file contained in a bundle very easily.
The only way I could see how to do this was if your bundle was a directory bundle (opposed to a jar'ed bundle) and you pointed to the path to the file located inside the directory bundle located on disk. This is rather brittle though.
Tom.
Previous Topic:p2 ant tasks
Next Topic:Product export fails: exe does not start
Current Time: Tue Jan 23 10:22:54 GMT 2018
Powered by FUDForum. Page generated in 0.01740 seconds
