Home » Eclipse Projects » DSDP - Target Management » RSE using Telnet instead of SSH(How to connect a Remote System over Telnet instead of SSH, preferable while still using FTP for file transfers.)
RSE using Telnet instead of SSH [message #546266] Mon, 12 July 2010 10:53 Go to next message
Martin Svensson is currently offline Martin SvenssonFriend
How can I connect to a remote system that has an FTP server and a Telnet server, but no SSH server?
I tried using a "Telnet Only (Experimental)" connection, (with the drawback that I cannot use file transfers), but Eclipse still tries to use SSH!
Re: RSE using Telnet instead of SSH [message #639432 is a reply to message #546266] Tue, 16 November 2010 14:07 Go to previous message
Martin Oberhuber is currently offline Martin OberhuberFriend
Hm...
when you connect a "Telnet Only" connection, I cannot see how SSH would
be used... I'd recommend more investigations on your end to see what's
going wrong.
For Telnet + FTP, you could use a "UNIX" connection type and then choose
the Telnet Shells + FTP Files subsystems in the wizard. Make sure to
only connect relevant subsystems.
To make your user experience simpler (and allow connecting the
connection rather than individual subsystems), you can either install
FTP + Telnet only (ie uninstall dstore); or, you extend RSE by creating
your own system type that only supports telnet + FTP.
HTH,
Martin
Previous Topic:SSH tunnel through a Bastion host ?
Next Topic:RSE installation failed
Current Time: Wed Feb 21 20:59:26 GMT 2018
Powered by FUDForum. Page generated in 0.01610 seconds
