Home » Modeling » UML2 Tools » Newbie- UML2 tools source code compilation problems
Newbie- UML2 tools source code compilation problems [message #546090] Sat, 10 July 2010 21:44
Thang is currently offline ThangFriend
Hi there,
I want to extend the org.eclipse.uml2.diagram.statemachine plugin to build a "code generator" based on state machine.
My problem is that when I download the code from CSV it can not be compiled because of some error.
I'm using Galileo and installed these packages:
-EMF 2.5
-GMF 2.0 (also try 2.2)
-UML2 3.0
-UML2 tools 0.9.0
One of the errors is that :
org.eclipse.gmf.runtime.diagram.ui.editpolicies.LayoutEditPo licy can not be solved to a type.
I can't find the LayoutEditPolicy in "org.eclipse.gmf.runtime.diagram.ui.editpolicies" (in sdk) ???
Could someone please help me to solve this problem ? Which package I have to install to run the source code ?
Many thanks Smile
[Updated on: Sat, 10 July 2010 21:47]
Report message to a moderator
Previous Topic:MDT and Helios
Next Topic:Newbie- UML2 tools source code compilation problems
Current Time: Wed Apr 25 20:37:10 GMT 2018
Powered by FUDForum. Page generated in 0.01409 seconds
