Home » Eclipse Projects » Remote Application Platform (RAP) » RAP and GWT(RAP and GWT)
RAP and GWT [message #545911] Fri, 09 July 2010 15:08 Go to next message
Ashwani Kr Sharma is currently offline Ashwani Kr SharmaFriend
The goal of RAP stands as : "The RAP project aims to enable developers to build rich, Ajax-enabled Web applications by using the Eclipse development model, plug-ins and a Java-only API".
It is similar to GWT. GWT have its own programming model.
How do you guys see RAP against GWT as web application development platform ?
Ashwani Kr Sharma
Re: RAP and GWT [message #545928 is a reply to message #545911] Fri, 09 July 2010 15:25 Go to previous messageGo to next message
Stefan   is currently offline Stefan Friend
have you read
news://news.eclipse.org:119/fcpskd$h81$1@build.eclipse.org
and
news://news.eclipse.org:119/fva32s$m87$1@build.eclipse.org
Stefan.
Re: RAP and GWT [message #545945 is a reply to message #545928] Fri, 09 July 2010 16:33 Go to previous messageGo to next message
Originally posted by: ashw.kumar.gmail.cokm
On 09/07/2010 8:55 PM, Stefan Roeck wrote:
> have you read
> and
> Stefan.
Hi Stefan,
Thanks for your reply. I am not able to open these links. I tried news
client like Thunderbird too.
Can you guide how to access them or give some more easily accessible links ?
Thanks and Regards,
Ashwani Kr Sharma
Re: RAP and GWT [message #545946 is a reply to message #545928] Fri, 09 July 2010 16:36 Go to previous messageGo to next message
> have you read
> and
> Stefan.
Hi Stefan,
Thanks and Regards,
Ashwani Kr Sharma
Re: RAP and GWT [message #545972 is a reply to message #545946] Fri, 09 July 2010 17:59 Go to previous message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
same links from newsgroup archive:
http://www.eclipse.org/forums/index.php?t=tree&goto=4775 8&#msg_47758
http://www.eclipse.org/forums/index.php?t=tree&goto=8567 4&
HTH,
Ivan
>> have you read
>> and
>> Regards,
>> Stefan.
> Hi Stefan,
> links ?
> Thanks and Regards,
> Ashwani Kr Sharma
Previous Topic:Disabling select row in table on mouse right click
Next Topic:Problem including Prototype Library
Current Time: Sun May 27 08:16:14 GMT 2018
Powered by FUDForum. Page generated in 0.01539 seconds
