Home » Modeling » UML2 Tools » How to install UML2-Tools on Helios
How to install UML2-Tools on Helios [message #544887] Mon, 05 July 2010 21:24 Go to next message
Ed Willink is currently offline Ed WillinkFriend
Until a Helios release of UML2-Tools is made available to correct the
erroneous org.eclipse.emf.ocl dependency, the following workaround may
be used.
See
http://wiki.eclipse.org/MDT/OCL/FAQ#How_do_I_workaround_org. eclipse.emf.ocl_deprecation_in_Helios_and_later.3F
Ed Willink
Re: How to install UML2-Tools on Helios [message #545138 is a reply to message #544887] Tue, 06 July 2010 18:07 Go to previous messageGo to next message
Misoullee is currently offline MisoulleeFriend
Member
It is very unfortunate which UML2 TOOLS project is not active.
i wait for UML2 TOOLS 1.0 to be coming up in Helios ago long time.
i have worked many modeling projects with the UML2 TOOLS.
However, This solution is so pleasant for everyone use UML2TOOLS.
Thanks a lot.
Re: How to install UML2-Tools on Helios [message #545236 is a reply to message #544887] Wed, 07 July 2010 09:40 Go to previous messageGo to next message
Originally posted by: formatzeh.gmx.de
Thanks a lot Ed - this is a great help and works perfectly
Ed Willink wrote:
> Hi
> be used.
> See
> Regards
> Ed Willink
Re: How to install UML2-Tools on Helios [message #545436 is a reply to message #545236] Wed, 07 July 2010 18:05 Go to previous messageGo to next message
I'm pleased it helps, but beware that it is very dangerous, because it
practically claims that Galileo and Helios are the same, undermining
p2's ability to ensure consistency.
I've 'successfully' created an installation in which the Sample Ecore
Editor is not in the Open With menu so that when it is invoked manually
you get a perverse ClassNotFoundException.
Make sure that you install everything you may need from Helios sites,
then install the patch, then install UML2-Tools last. Don't install
anything else later.
Ed Willink
Re: How to install UML2-Tools on Helios [message #549367 is a reply to message #544887] Mon, 26 July 2010 14:14 Go to previous messageGo to next message
Christian Waniek is currently offline Christian WaniekFriend
Member
there is an incubation build which isn't far from a release build.
http:// modeling.eclipse.org/modeling/mdt/downloads/?project=uml2too ls&showAll=0&showMax=5&sortBy=date
This should do a better job than any workaraound as there are also a lot of fixed bugs and enhancements in it.
Christian Waniek
Re: How to install UML2-Tools on Helios [message #625823 is a reply to message #544887] Tue, 06 July 2010 18:07 Go to previous messageGo to next message
Member
Thanks a lot.
Re: How to install UML2-Tools on Helios [message #625825 is a reply to message #544887] Wed, 07 July 2010 09:40 Go to previous messageGo to next message
Ed Willink wrote:
> Hi
> be used.
> See
> Regards
> Ed Willink
Re: How to install UML2-Tools on Helios [message #625826 is a reply to message #545236] Wed, 07 July 2010 18:05 Go to previous messageGo to next message
Ed Willink
Re: How to install UML2-Tools on Helios [message #625869 is a reply to message #544887] Mon, 26 July 2010 14:14 Go to previous messageGo to next message
Member
http://modeling.eclipse.org/modeling/mdt/downloads/?project= uml2tools&showAll=0&showMax=5&sortBy=date
Christian Waniek
Re: How to install UML2-Tools on Helios [message #635667 is a reply to message #544887] Wed, 27 October 2010 16:51 Go to previous messageGo to next message
Thomas Jung is currently offline Thomas JungFriend
I tried to get that workaround running with Eclipse 3.6.1
(Modeling) on Windows, but get the error:
---snip---
'Installing Software' has encountered a problem.
An error occured while collecting items to be installed
---snap---
See:
http://tjung.lima-city.de/eclipse/update/local/
if I update the "mdt-uml2tools-Update-incubation-0.9.0"
from a local repository.
Btw:
A manual install and just copy the content of
"mdt-uml2tools-SDK-incubation-N201009140751.zip"
to the eclipse directory shows only
"Composite Sructures Diagram", "Deployment Diagram"
"Sequence Diagram" and "Use Case Diagram", but not
"Class Diagram" or other diagrams.
What do I have to do to enable the other types of diagrams
or what can I do to get all that UML2 Tools running?
Thomas
Re: How to install UML2-Tools on Helios [message #653040 is a reply to message #544887] Tue, 08 February 2011 08:34 Go to previous messageGo to next message
sunita Mising name is currently offline sunita Mising nameFriend
hi
could anyone tell me how to use uml2 tools in eclipse helios .i have download the uml2 tools from this site http://modeling.eclipse.org/modeling/mdt/downloads/?project= uml2tools but i dnt knw how to use it ......................
Re: How to install UML2-Tools on Helios [message #658846 is a reply to message #544887] Thu, 10 March 2011 02:44 Go to previous message
ray  is currently offline ray Friend
Very Happy thanks, it works well
Previous Topic:Extension Point for catching "Add Note"
Next Topic:Switching package view breaks diagram
Current Time: Sat May 26 10:11:03 GMT 2018
Powered by FUDForum. Page generated in 0.02579 seconds
