Home » Eclipse Projects » Rich Client Platform (RCP) » FileNotFoundException -- Eclipse Plugin
FileNotFoundException -- Eclipse Plugin [message #544683] Mon, 05 July 2010 09:19 Go to next message
vaideeswaran  is currently offline vaideeswaran Friend
Hi All,
I have a single plugin and added a new package to the current one. I dont have to use Buddy Classloading as there is only one plugin/project. I have added the xml file to the build path and also added the folder containing the xml to the runtime tab of the Manifest.mf. I use the
ClassPathXmlApplicationContext to access this xml file. I am getting FileNotFoundException.I am struggling with this issue for the last 4 days. Kindly advice.Your help in this is much appreciated.
I placed the xml file in project root folder,project root folder/resources/,src folder....
But still i am getting the exception. This is an eclipse RCP plugin project so there wont be the runtime classpath tab when I click run configurations.
V
Re: FileNotFoundException -- Eclipse Plugin [message #545758 is a reply to message #544683] Thu, 08 July 2010 23:58 Go to previous messageGo to next message
Wim Jongman is currently offline Wim JongmanFriend
Try this class:
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/reference/api/org/eclipse/core/runtime/Fil eLocator.html
Also, in the scenario uyou describe,
getClass().getClassLoader().getResource(string) is also an option.
Wim
> Hi All,
> Thanks
> V
Re: FileNotFoundException -- Eclipse Plugin [message #759075 is a reply to message #545758] Fri, 25 November 2011 23:32 Go to previous messageGo to next message
Missing name Missing name is currently offline Missing name Missing nameFriend
I have exactly the same problem. Have you managed to sort the problem?
Julien.
Re: FileNotFoundException -- Eclipse Plugin [message #759318 is a reply to message #759075] Mon, 28 November 2011 11:15 Go to previous message
Ellis Yu is currently offline Ellis YuFriend
Same here. I've struggled this problem for three days. If I ran in junit test, I can read the xml without problem. But if I ran in my RCP app, the xml file can't be found. The problem seem related to classloader issue. That's difficult for beginner to figure out.
Ellis
Previous Topic:memorize window size and posotion : RCP application
Next Topic:Calculate RCP Product Classpath for Embedded Eclipse Compiler
Current Time: Sat May 26 21:38:34 GMT 2018
Powered by FUDForum. Page generated in 0.02249 seconds
