Home » Newcomers » Newcomers » JUnit Problem
JUnit Problem [message #544481] Fri, 02 July 2010 19:30 Go to next message
Lafare  is currently offline Lafare Friend
I'm very new to Java/Eclipse.
I've installed the Eclipse Helios version on my PC/Windows.
I've created a very basic project HelloWorld that works fine.
I'm trying to create a JUnit test using the wizard and when I launch the test, I get the following error. (I tried JUnit 3 and 4, same result):
java.lang.NoClassDefFoundError: org/eclipse/jdt/internal/junit/runner/RemoteTestRunner
Caused by: java.lang.ClassNotFoundException: org.eclipse.jdt.internal.junit.runner.RemoteTestRunner
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
Exception in thread "main"
I don't know how to tackle this error? Any help to correct this problem would be appreciated.
Thank you by advance
Re: JUnit Problem [message #544488 is a reply to message #544481] Fri, 02 July 2010 20:24 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
On 7/2/2010 1:30 PM, Lafare wrote:
> Hello,
> [snip]
1. Right-click on your project and choose Build Path -> Configure Build
Path.
2. Click on the Libraries tab.
3. Click Add Library.
4. Click JUnit, then choose either JUnit 3 or 4 depending on which you
want to use (if you're going to use Java 5 or 1.6, I'd suggest JUnit 4).
5. Right-click the JUnit test you wanted to run and choose Run As ->
JUnit Test.
You shouldn't be missing this symbol now, I think.
Russ Bateman
Re: JUnit Problem [message #544498 is a reply to message #544488] Fri, 02 July 2010 22:24 Go to previous messageGo to next message
The correct JUnit lib was automatically included by the wizard.
I tried with both version of JUnit (the correct lib was proposed) but the error remained..
Re: JUnit Problem [message #544633 is a reply to message #544498] Mon, 05 July 2010 07:19 Go to previous message
Dani Megert is currently offline Dani MegertFriend
You need to check the launch configuration.
Dani
Previous Topic:Automatic perspective switch
Next Topic:Custom Editor Keys on Mac OSX
Current Time: Mon Jun 25 18:11:29 GMT 2018
Powered by FUDForum. Page generated in 0.03691 seconds
