Home » Eclipse Projects » Buckminster » buckminster.properties not obeyed ? difference between headless and eclipse based build
buckminster.properties not obeyed ? difference between headless and eclipse based build [message #543679] Wed, 30 June 2010 09:33 Go to next message
Bernhard Merkle is currently offline Bernhard MerkleFriend
Member
I am really puzzeled as i have a difference between headless buckminster and eclipse based buckminster.
Both headless bm an eclipse bm point to the SAME workspace and hence the SAME buckminster.properties file.
I have verified this via:
- make a change in eclipse in the buckminster.properties file. --> I can see this immediately in hudson in the workspace explorer.
- change the name of buckminster.properties to buckminster.properties.save --> the hudson build fails because of the missing file.
Now as you can see in the output below there are diffs between headless and eclipse based buckminster:
- the source plugin is build, depite the fact that i have set cbi.include.source = false
- the jar file is NOT signed depite the fact that I have set the relevant settings in the buckminster.properties.
how can I track this problem ?
does the headless bm cache config settings somewhere ? or do i have to handle them specially ?
thanks,
Bernhard.
---buckminster.properties----------------------------------- ----
# How .qualifier in versions should be replaced
qualifier.replacement.*=generator:lastRevision
# Where all the output , temp file should go
buckminster.output.root=${user.home}/p2site
buckminster.temp.root=${user.home}/tmp/p2site.tmp
# Deliver signed JAR files
local.keystore.path = W:/keystore/mykeystore
local.keystore.alias = eclipse_sick
local.keystore.password = secret
site.signing = true
signing.type = local
# Deliver no source files
---output of buckminster in eclipse---------------------------------------
[start de.sick.sopas.generator.srt:osgi.bundle$2.29.858#eclipse.bui ld]
[end de.sick.sopas.generator.srt:osgi.bundle$2.29.858#eclipse.bui ld]
[start de.sick.sopas.generator.srt:osgi.bundle$2.29.858#bundle.jar]
[end de.sick.sopas.generator.srt:osgi.bundle$2.29.858#bundle.jar]
[start de.sick.sopas.generator.srt.feature:eclipse.feature$1.0.0.qu alifier#copy.plugins]
[end de.sick.sopas.generator.srt.feature:eclipse.feature$1.0.0.qu alifier#copy.plugins]
[start de.sick.sopas.generator.srt.feature:eclipse.feature$1.0.0.qu alifier#site.signed]
[ant] Enter Passphrase for keystore:
[end de.sick.sopas.generator.srt.feature:eclipse.feature$1.0.0.qu alifier#site.signed]
[start de.sick.sopas.generator.srt.feature:eclipse.feature$1.0.0.qu alifier#manifest]
[end de.sick.sopas.generator.srt.feature:eclipse.feature$1.0.0.qu alifier#manifest]
[start de.sick.sopas.generator.srt.feature:eclipse.feature$1.0.0.qu alifier#site.p2]
[end de.sick.sopas.generator.srt.feature:eclipse.feature$1.0.0.qu alifier#site.p2]
---output of headless buckminster in hudson---------------------------------------
INFO: perform '-D' 'target.os=*' '-D' 'target.ws=*' '-D' 'target.arch=*' '-D' 'qualifier.replacement.*=I20100630-5' 'de.sick.sopas.generator.srt.feature#site.p2'
INFO: [start de.sick.sopas.generator.srt:osgi.bundle$2.29.858#eclipse.bui ld]
INFO: [end de.sick.sopas.generator.srt:osgi.bundle$2.29.858#eclipse.bui ld]
INFO: [start de.sick.sopas.generator.srt:osgi.bundle$2.29.858#source.bund le.jar]
INFO: [end de.sick.sopas.generator.srt:osgi.bundle$2.29.858#source.bund le.jar]
INFO: [start de.sick.sopas.generator.srt.feature:eclipse.feature$1.0.0.qu alifier#copy.plugins]
INFO: [end de.sick.sopas.generator.srt.feature:eclipse.feature$1.0.0.qu alifier#copy.plugins]
INFO: [start de.sick.sopas.generator.srt.feature:eclipse.feature$1.0.0.qu alifier#site.p2]
INFO: [end de.sick.sopas.generator.srt.feature:eclipse.feature$1.0.0.qu alifier#site.p2]
Finished: SUCCESS ---output of hudson---------------------------------------
Re: buckminster.properties not obeyed ? differenc e between headless and eclipse based build [message #543699 is a reply to message #543679] Wed, 30 June 2010 10:47 Go to previous messageGo to next message
Henrik Lindberg is currently offline Henrik LindbergFriend
The features you are using are fairly recent. Could it be that you are
executing an older version of BM?
- Henrik
Bernhard Merkle <bernhard.merkle@gmail.com> wrote:
> Hi
> missing file.
> thanks,
> Bernhard.
> site.signing = true
> ld]
> [ant] Enter Passphrase for keystore: [end
> alifier#manifest]
> alifier#manifest]
> alifier#site.p2]
> alifier#site.p2]
> 'de.sick.sopas.generator.srt.feature#site.p2' INFO: [start
> de.sick.sopas.generator.srt:osgi.bundle$2.29.858#eclipse.bui ld] INFO:
> INFO: [start
> INFO: [end
> INFO: [start
> INFO: [end
> alifier#copy.plugins] INFO: [start
> alifier#site.p2]
> INFO: [end
> alifier#site.p2]
- henrik
Re: buckminster.properties not obeyed ? differenc e between headless and eclipse based build [message #543711 is a reply to message #543699] Wed, 30 June 2010 11:35 Go to previous messageGo to next message
Member
Henrik Lindberg wrote on Wed, 30 June 2010 06:47
- henrik
how can I query the version ?
I have made a dir listing of my headless installation please see below.
I also added a -F and -P switch to the relevant commands and now it triggers the operation.
The signing fails actually but that may be a path related issue of jarsigner.exe)
and I do not produce the source plugin so it picks up the properties setting.
however it is very irritating that WITHOUT -F and -P it still works but with other behaviour.
And without the properties file it does not work at all (which proved that the properties are read but not used if i do not specify -F and -P) . Is this a bug ?
thanks,
Berni.
importpreferences -F '${WORKSPACE}/de.sick.sopas.generator.srt.buckminster/buckmi nster.properties'
build
perform -D target.os=* -D target.ws=* -D target.arch=* -D qualifier.replacement.*=${version} -P '${WORKSPACE}/de.sick.sopas.generator.srt.buckminster/buckmi nster.properties' de.sick.sopas.generator.srt.feature#site.p2
Verzeichnis von C:\ide\ibm\buckminster-headless-3.6\plugins
07.06.2010 09:39 <DIR> org.eclipse.buckminster.ant_1.2.360.r11210
21.05.2010 00:14 50.662 org.eclipse.buckminster.cmdline_1.0.350.r11425.jar
21.05.2010 00:17 1.045.442 org.eclipse.buckminster.core_1.2.360.r11436.jar
21.05.2010 00:17 48.407 org.eclipse.buckminster.cvs_1.1.0.r11436.jar
21.05.2010 00:16 47.643 org.eclipse.buckminster.download_1.1.0.r11379.jar
21.05.2010 00:16 15.432 org.eclipse.buckminster.executor_1.0.0.r11341.jar
21.05.2010 00:16 19.017 org.eclipse.buckminster.fetcher_1.0.0.r11210.jar
21.05.2010 00:17 30.006 org.eclipse.buckminster.generic_1.0.0.r11210.jar
21.05.2010 00:14 18.989 org.eclipse.buckminster.installer_1.1.0.r11336.jar
21.05.2010 00:18 35.745 org.eclipse.buckminster.jarprocessor_1.0.0.r11295.jar
07.06.2010 09:39 <DIR> org.eclipse.buckminster.jdt_1.0.0.r11394
21.05.2010 00:18 19.807 org.eclipse.buckminster.junit_1.0.0.r11240.jar
21.05.2010 00:18 55.833 org.eclipse.buckminster.maven_1.2.0.r11234.jar
21.05.2010 00:22 71.430 org.eclipse.buckminster.model.common.edit_1.1.0.r11210.jar
21.05.2010 00:22 108.252 org.eclipse.buckminster.model.common_1.1.0.r11210.jar
21.05.2010 00:17 33.448 org.eclipse.buckminster.osgi.filter_1.0.0.r11266.jar
07.06.2010 09:39 <DIR> org.eclipse.buckminster.pde_1.2.0.r11438
21.05.2010 00:22 56.819 org.eclipse.buckminster.rmap.edit_1.1.0.r11210.jar
21.05.2010 00:22 16.449 org.eclipse.buckminster.rmap.psf.edit_1.0.0.r11210.jar
21.05.2010 00:22 32.803 org.eclipse.buckminster.rmap.psf_1.1.0.r11210.jar
21.05.2010 00:22 65.786 org.eclipse.buckminster.rmap_1.1.0.r11210.jar
21.05.2010 00:14 39.909 org.eclipse.buckminster.runtime_1.2.0.r11375.jar
21.05.2010 00:17 27.344 org.eclipse.buckminster.sax_1.0.0.r11210.jar
21.05.2010 00:22 35.520 org.eclipse.buckminster.subversion_1.0.0.r10759.jar
21.05.2010 00:22 21.105 org.eclipse.buckminster.subversive_1.0.0.r10908.jar
21.05.2010 00:22 40.077 org.eclipse.buckminster.team.psf_1.0.0.jar
21.05.2010 00:17 24.392 org.eclipse.buckminster.team_1.0.0.r11424.jar
Re: buckminster.properties not obeyed ? differenc e between headless and eclipse based build [message #543951 is a reply to message #543711] Thu, 01 July 2010 07:43 Go to previous message
Thomas Hallgren is currently offline Thomas HallgrenFriend
>> executing an older version of BM? - henrik
> jarsigner.exe)
> setting.
> . Is this a bug ?
I don't understand this fully. Are you saying that the old buckminster
magically guesses what property file to use?
Without the -F the importpreferences assumes stdin. It's always been
that way. AFAIK, buckminster never reads (and never has read) a property
file unless you specify -P <file>
- thomas
Previous Topic:qualifier replacement across projects
Next Topic:psf import with different readtype?
Current Time: Sat Jan 20 15:26:39 GMT 2018
Powered by FUDForum. Page generated in 0.02371 seconds
