Home » Language IDEs » PHP Development Tools (PDT) » [SOLVED] how to ignore dltk problems for specific files and directories(how to ignore dltk problems for specific files and directories)
[SOLVED] how to ignore dltk problems for specific files and directories [message #543535] Tue, 29 June 2010 17:29 Go to next message
cirpo  is currently offline cirpo Friend
hi,
I have a symfony project, everything works fine but i can't exclude specific dltk problems that aren't really problems.
For example:
helper.php that is a skeleton file
class ##MODULE_NAME##GeneratorHelper extends Base##UC_MODULE_NAME##GeneratorHelper
I excluded other files(xml validator, html validator etc) succesfully but not those with dltk problems.
thanks,
cirpo
[Updated on: Tue, 29 June 2010 18:36]
Report message to a moderator
Re: how to ignore dltk problems for specific files and directories [message #543556 is a reply to message #543535] Tue, 29 June 2010 18:36 Go to previous messageGo to next message
Solved,
I excluded those files from the built path and I got no more dltk problems.
thanks
cirpo
Re: how to ignore dltk problems for specific files and directories [message #544423 is a reply to message #543556] Fri, 02 July 2010 15:45 Go to previous message
NoobieRoobie is currently offline NoobieRoobieFriend
Build Path settings can be pretty powerful.
Previous Topic:PHP syntax highlighting
Next Topic:how to use plugin PDT on Eclipse for Java?
Current Time: Mon Feb 19 00:39:02 GMT 2018
Powered by FUDForum. Page generated in 0.01987 seconds
