Home » Language IDEs » PHP Development Tools (PDT) » eclipse-phpeclipse (galileo and halileo)
eclipse-phpeclipse [message #542812] Sat, 26 June 2010 10:26 Go to next message
Lefu  is currently offline Lefu Friend
hi guys,
I am new to eclipse, and would really like to understand the difference.
I have fedora 13 64bit gnome only. I installed eclipse-jdt-3.5.2-1.fc13.x86_64,eclipse-pde-3.5.2-1.fc13.x86 _64 and eclipse-phpeclipse-1.2.3-1.fc13.noarch, all as Galileo.(installed using YUM)
I then downloaded eclipse-php-helios-linux-gtk-x86_64.tar.gz all in one- they say on the website.
I just need syntax highlighter for html, css and js files, which I don't have in galileo mode, but with the latter helios I get all syntax highlighters I need.
HOW DO I MERGE THEM? so that I can run eclipse normally under applications without getting into terminal and running eclipse from the source? thank you.
I hope this questins belong to this forum..
[Updated on: Sat, 26 June 2010 16:50]
Report message to a moderator
Re: eclipse-phpeclipse [message #544412 is a reply to message #542812] Fri, 02 July 2010 15:28 Go to previous message
NoobieRoobie is currently offline NoobieRoobieFriend
There is no need to merge stuff.
Just use the all-in-one package to do an installation on it's own. Everything you need for PDT is already in there (except maybe the debugger which is normal).
Give it a different workspace then your previous installation (if you already made one).
[Updated on: Fri, 02 July 2010 15:28]
Previous Topic:PHP Search "no Interpreter"
Next Topic:PHP syntax highlighting
Current Time: Tue Jan 23 18:14:36 GMT 2018
Powered by FUDForum. Page generated in 0.01538 seconds
