Home » Language IDEs » C / C++ IDE (CDT) » Helios 64 bit with Qt Eclipse Integration?
Helios 64 bit with Qt Eclipse Integration? [message #542003] Wed, 23 June 2010 13:40 Go to next message
John McCabe is currently offline John McCabeFriend
Hi Guys
A couple of weeks ago I tried installing the 64 bit release candidate
of Eclipse Helios and then Qt Eclipse Integration on top of it. It
didn't work; there was no sign of the Qt features working in there.
Am I right in thinking that's going to always be the case until Nokia
release a 64 bit version of the integration package?
I'm downloading both 32 bit and 64 bit Eclipse Helios at the moment,
so which one gets installed depends on the answer.
Thanks for your help.
John
PS - One final question - what's the best way to install the official
Helios release given that I'm currently running RC4 (I think). Should
I overwrite what I've got or start afresh. I think the only additional
feature I've installed is GDB Hardware Debugging from a local download
of one of the CDT nightly builds.
Thanks again.
Re: Helios 64 bit with Qt Eclipse Integration? [message #542017 is a reply to message #542003] Wed, 23 June 2010 14:29 Go to previous messageGo to next message
Doug Schaefer is currently offline Doug SchaeferFriend
John McCabe wrote on Wed, 23 June 2010 09:40
Hi Guys
That's a question for the Qt guys. I am working with the Nokia Eclipse guys as we debate the best approach to improve Qt support for the CDT. That may or may not involve reusing the above plug-ins. But yeah, I doubt 64-bit will work.
Thanks again.
That one's easy. Just do a Check for Updates. It'll always find the latest bits available and offer to install them for you.
Re: Helios 64 bit with Qt Eclipse Integration? [message #542037 is a reply to message #542017] Wed, 23 June 2010 15:03 Go to previous messageGo to next message
On Wed, 23 Jun 2010 10:29:50 -0400, Doug Schaefer <cdtdoug@gmail.com>
>> Hi Guys
Fair enough. I can live with that for the moment.
>Quote:
Ok - I'll do it that way.
Thanks for your help, and your efforts on CDT.
Re: Helios 64 bit with Qt Eclipse Integration? [message #545209 is a reply to message #542017] Wed, 07 July 2010 07:34 Go to previous messageGo to next message
michelle  is currently offline michelle Friend
Member
Doug Schaefer wrote on Wed, 23 June 2010 16:29
Just a little question here of compatibility: I'm running windows7 64-bit but have Helios 32-bit running. I only ever need to develop 32-BIT applications.
The Eclipse Integration plugin at http://qt.nokia.com/developer/eclipse-integration/ specifies 32-BIT - - will this plugin work on my current setup?
thanks in advance, michelle
[Updated on: Wed, 07 July 2010 07:35]
Report message to a moderator
Re: Helios 64 bit with Qt Eclipse Integration? [message #545275 is a reply to message #545209] Wed, 07 July 2010 10:30 Go to previous messageGo to next message
On Wed, 07 Jul 2010 09:34:02 +0200, michelle
>Just a little question of compatibility: I'm running windows7 64-bit although I have Helios 32-BIT. I only need to develop 32-BIT applications.
Yes. That's exactly what I'm using.
Re: Helios 64 bit with Qt Eclipse Integration? [message #545292 is a reply to message #545275] Wed, 07 July 2010 11:36 Go to previous messageGo to next message
Member
perfect. Thanks John.
Re: Helios 64 bit with Qt Eclipse Integration? [message #545293 is a reply to message #545292] Wed, 07 July 2010 11:39 Go to previous messageGo to next message
Member
maybe I'm asking the obvious, but why wouldn't this be availible via HELP > INSTALL NEW SOFTWARE ? ...because QT have to give permission?
Re: Helios 64 bit with Qt Eclipse Integration? [message #545311 is a reply to message #545293] Wed, 07 July 2010 12:09 Go to previous messageGo to next message
On Wed, 07 Jul 2010 13:39:30 +0200, michelle
When you install it, you end up with a folder in Program Files
(x86)\Nokia\Eclipse that contains a load of dlls that, although most
of them are in the Qt\2010.02.1\bin folder (or lib or something),
includes some that don't appear to be there, e.g. qtcppdesigner.dll,
qtcppproparser.dll and qtcppqrceditor.dll.
My guess is that Install New Software is perhaps mainly designed for
installing Java based plug-ins and adding native dlls isn't well
supported.
I might be totally wrong though, and I hope someone corrects me if
that is the case.
Re: Helios 64 bit with Qt Eclipse Integration? [message #545315 is a reply to message #545311] Wed, 07 July 2010 12:39 Go to previous messageGo to next message
Member
oh here we go, I got a something from Doug Schaefer's blog on Eclipse CDT: CDT, Toward World Domination)
The biggest complaint I get from the user community is how hard it is to set up CDT for their platform, especially developers using Windows. That's where Wascana comes in. There's also a variety of environments that don't come with out of the box support, like Qt and Mac Cocoa...
Qt is a natural for cross platform development, so is CMake and Autotools build environments. And I'm helping with CDT support for Android native development. These are things CDT should support out of the box to enable my plan for world domination Smile. And that's what motivates me to keep plugging away.
[Updated on: Wed, 07 July 2010 12:41]
Re: Helios 64 bit with Qt Eclipse Integration? [message #545318 is a reply to message #545315] Wed, 07 July 2010 12:42 Go to previous messageGo to next message
Member
...and still trying to get QT installed...
Re: Helios 64 bit with Qt Eclipse Integration? [message #545352 is a reply to message #545275] Wed, 07 July 2010 13:48 Go to previous messageGo to next message
Member
John McCabe wrote on Wed, 07 July 2010 12:30
ummm... John (or anyone), just to make sure I'm on the right track here whilst I download the 279MB SDK file over a dial-up connection (ouch):
Q1). I write my apps in C (not C++) - will QT still work for me?
Q2) MY STEPS TO INSTALL (are they correct?):
i]. Download & install the windows QT SDK http://get.qt.nokia.com/qtsdk/qt-sdk-win-opensource-2010.04. exe
ii]. Download & install Eclipse Integration plugin for C++ http://get.qt.nokia.com/qteclipse/qt-eclipse-integration-win 32-1.6.1.exe
iii]. Open up eclipse. WINDOW | PREFERENCES | QT --- set the paths as found in the installation of the SDK in [i]
...is that correct? thanks a lot. Michelle
[Updated on: Wed, 07 July 2010 13:53]
Re: Helios 64 bit with Qt Eclipse Integration? [message #545360 is a reply to message #545352] Wed, 07 July 2010 14:06 Go to previous message
On Wed, 07 Jul 2010 15:48:41 +0200, michelle
>ummm... John (or anyone with the answer), just to make sure I'm on the right track here whilst I download a 279MB file over a dial-up connection (ouch):
To be honest, I have no idea. That may be an issue, but I've never
tried it. I've never tried interfacing C code to C++ class libraries
in that direction; C++ using C libraries isn't difficult, but I've not
used it the other way.
Assuming you already have Eclipse installed...
As far as I remember, yes.
FWIW - It's definitely worth avoiding installing Qt anywhere other
than the default. Also, the Qt Eclipse Integration adds a "Start
Eclipse With MinGW" link on the menu. That's worth using although it
sets your path to the MinGW location plus a couple of other windows
folders only. I tend to edit the file that runs that (c:\Program Files
(x86)\Nokia\Eclipse\Start.bat) so that it just prepends the MinGW
folder to my existing path.
Previous Topic:Pydev WxPython usage
Next Topic:the hello world project does not give any output
Current Time: Sun May 20 19:25:52 GMT 2018
Powered by FUDForum. Page generated in 0.01926 seconds
