Home » Modeling » TMF (Xtext) » MWE2 class path issue(MWE2 uses class path instead of specfified file)
MWE2 class path issue [message #541801] Tue, 22 June 2010 14:54 Go to next message
Bernhard Cygan is currently offline Bernhard CyganFriend
When I try to run a workflow file from a specific location, the location is ignored and instead the workflow/*.mwe2 path is used, meaning that the code will be generated to src-gen instead of /home/...
module workflow.AppScriptTemplateJavaGenerator
import org.eclipse.emf.mwe.utils.*
import de.itemis.xtext.antlr.*
var sourceDir = "src/model"
var targetDir = "/home/somebody/TEST"
var fileEncoding = "Cp1252"
Workflow {
/* .. reader definiton omitted .. */
component = org.eclipse.xpand2.Generator {
metaModel = org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel {}
expand = "templates::Template::main FOREACH model"
outlet = {
path = targetDir
fileEncoding = fileEncoding
Is this a feature or a bug ? Or do I need to set the specified location targetDir differently ?
Thanks for your time
Bernhard
Re: MWE2 class path issue [message #542327 is a reply to message #541801] Thu, 24 June 2010 14:20 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Bernhard,
this seems to be a bug. Would you please be so kind and file a ticket
and attach a reproducable example?
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 22.06.10 16:54, schrieb Bernhard Cygan:
> Workflow {
> outlet = {
> path = targetDir
> Bernhard
Re: MWE2 class path issue [message #543379 is a reply to message #542327] Tue, 29 June 2010 09:17 Go to previous message
see https://bugs.eclipse.org/bugs/show_bug.cgi?id=318283
Previous Topic:New styled labels for outlineview and contentassist
Next Topic:How to get a Injector from a xtextdocument
Current Time: Thu May 24 19:36:05 GMT 2018
Powered by FUDForum. Page generated in 0.01964 seconds
