Home » Newcomers » Newcomers » Eclipse "running" xml files
Eclipse "running" xml files [message #541587] Mon, 21 June 2010 16:47 Go to next message
No real name is currently offline No real nameFriend
Since I've installed eclipse on my new machine, I've had a problem with eclipse "running" xml files. If I am editing an xml file within a project and I hit run, eclipse attempts to run the xml file rather than the project which contains it. When this happens I get a "No embedded stylesheet instruction for file" error, and a blank xml output file (foo.xml generates foo.out.xml). Is there a way to configure eclipse to run the project containing the xml file I'm editing (as it does for any other type of file I'm editing) rather than the file itself?
Re: Eclipse "running" xml files [message #541941 is a reply to message #541587] Wed, 23 June 2010 09:53 Go to previous message
Patrick is currently offline PatrickFriend
Member
See this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=287951
A workaround is to set the Launching preference to "Always launch the
previously launched application".
Previous Topic:Problem with installing PlugIns
Next Topic:Start internal Tomcat from ANT task
Current Time: Mon Apr 23 23:26:36 GMT 2018
Powered by FUDForum. Page generated in 0.02941 seconds
