Home » Modeling » UML2 » how to transform uml1.4 to uml2
how to transform uml1.4 to uml2 [message #541273] Sat, 19 June 2010 10:39 Go to next message
wafaa is currently offline wafaaFriend
hi all
can some one tell me how to change from UML1.4 file to UML2
I have a file that can not be loaded in magicdraw because it is uml1.4
so please how can I convert it to uml2
i did not create it, i got it ready.
Re: how to transform uml1.4 to uml2 [message #541406 is a reply to message #541273] Mon, 21 June 2010 02:04 Go to previous messageGo to next message
Rafael Chaves is currently offline Rafael ChavesFriend
Wafaa,
MagicDraw does not use Eclipse UML2 as its native format (yet), so this is not the right forum for that kind of question. You might want to ask that on the MagicDraw support forum.
Rafael
http://abstratt.com/blog
Re: how to transform uml1.4 to uml2 [message #541517 is a reply to message #541406] Mon, 21 June 2010 13:05 Go to previous messageGo to next message
thanks Rafeal but I usually creates diagrams in magicdraw and export them as UML2 and they are opened in Eclipse.
I did not understand your answer, is it that my diagrams are opened due to their correct UML format not because it is the standard for magicdraw, magicdraw uses many standards.
but the error shows that the problem is that because the file is somehow UML1.4 which is not supported by magicdraw
but far away fro this problem cant i convert it to UML2 though??
I will try to find the MagicDraw forum if it exists??
Re: how to transform uml1.4 to uml2 [message #541675 is a reply to message #541517] Tue, 22 June 2010 06:56 Go to previous messageGo to next message
Oh, I see what you mean now. All you want is to be able to open a UML 1.4 model using the Eclipse UML2 API.
This thread might be of interest:
http://www.eclipse.org/forums/index.php?t=tree&goto=4753 23
Re: how to transform uml1.4 to uml2 [message #542853 is a reply to message #541675] Sat, 26 June 2010 19:53 Go to previous messageGo to next message
thanks a lot rafeal for you help and informative reply, I wonder if I
can have more information on endlinkData and related operation!!:D
if yes i will open new thread
Re: how to transform uml1.4 to uml2 [message #542880 is a reply to message #542853] Sat, 26 June 2010 23:27 Go to previous messageGo to next message
Start the thread and then you will know. Smile
Re: how to transform uml1.4 to uml2 [message #628534 is a reply to message #542853] Sat, 26 June 2010 23:27 Go to previous message
Start the thread and then you will know. :)
Previous Topic:Re: UML Factory
Next Topic: Redefinition Contexts
Current Time: Mon May 21 09:15:19 GMT 2018
Powered by FUDForum. Page generated in 0.01821 seconds
