Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EEF] Custom Toolkit Widgets(How to use dynamic templates for a custom property editor widget?)
[EEF] Custom Toolkit Widgets [message #540684] Thu, 17 June 2010 00:57 Go to next message
Mike Morrell is currently offline Mike MorrellFriend
I have created a custom combo viewer control and I would like to use it as a custom toolkit widget for one of my properties. Is it possible to extend the code generator to use my custom widget? I created a custom.toolkit model and added my custom widget to it. I then linked to it from my *.components file. When I generate the EEF architecture the code generator throws an error when I get to the custom widget. I think it is because there is no code template for my custom widget. Is there a way to add a dynamic code generation template so my widget will be generated?
[Updated on: Thu, 17 June 2010 13:24]
Report message to a moderator
Re: [EEF] Custom Toolkit Widgets [message #541566 is a reply to message #540684] Mon, 21 June 2010 14:26 Go to previous messageGo to next message
Stephane Bouchet is currently offline Stephane BouchetFriend
Hi mike,
you have done the first part of the job.
We are writing a wiki page that will explain in details what you have to
do.
the difficult part is that you hve to create a new Acceleo generator
project and extends some of the templates with guards that are compliant
with your widget.
Sorry for the delay,
Stephane
> generated?
Re: [EEF] Custom Toolkit Widgets [message #553213 is a reply to message #540684] Mon, 16 August 2010 17:02 Go to previous messageGo to next message
Joshua Baran is currently offline Joshua BaranFriend
I'm also interested in adding some custom widgets. Is this wiki page complete yet? If so, please post a link to it.
Josh
Re: [EEF] Custom Toolkit Widgets [message #553902 is a reply to message #553213] Thu, 19 August 2010 11:36 Go to previous messageGo to next message
Florian Barbin is currently offline Florian BarbinFriend
Hi Josh,
Unfortunately we didn't have time to progress on that tutorial. We hope to make it available very soon.
Florian
Florian Barbin - Obeo
Re: [EEF] Custom Toolkit Widgets [message #553945 is a reply to message #540684] Thu, 19 August 2010 13:49 Go to previous messageGo to next message
Sylvain EVEILLARD is currently offline Sylvain EVEILLARDFriend
This isn't that hard actually.
You create a plug-in that has the acceleo nature.
You then have to code 4 templates for each widget.
You'll find the templates to override in org.eclipse.emf.eef.codegen.widgets.api.
The best solution is to take as exemple the existing widgets.
Once you've done that you have to use the 'org.eclipse.acceleo.engine.dynamic.templates' extension point on your plug-in and add as templates the path of the templates you defined.
The plug-in has to be loaded to be used at the generation time so you can't have it in the same workspace as your EEF project I guess. Either you have to export it in a jar format or you launch a dynamic eclipse instance and generate your EEF project in this new workspace.
Re: [EEF] Custom Toolkit Widgets [message #554036 is a reply to message #540684] Thu, 19 August 2010 19:16 Go to previous message
Great, with that help I was able to get it working.
Thanks!
Previous Topic:Emfatic download
Next Topic:Edapt - Status?
Current Time: Thu Jan 18 12:14:37 GMT 2018
Powered by FUDForum. Page generated in 0.02129 seconds
