Home » Newcomers » Newcomers » Stop debugging
Stop debugging [message #540368] Tue, 15 June 2010 19:52 Go to next message
Originally posted by: news.s237965939.online.de
When I start debugging the perspective changes to 'Debug' but when
debugging is finished it doesn't change back. How can that be done for
either J2SE oe J2ME?
TIA,
Hans
Re: Stop debugging [message #540373 is a reply to message #540368] Tue, 15 June 2010 20:53 Go to previous messageGo to next message
David M. Karr is currently offline David M. KarrFriend
Just press "Ctrl-f8", which should be bound to "Next Perspective". The previous perspective will likely be highlighted, and that's the perspective it will switch to.
If the highlighted perspective is not the one you want, then press the key again, and it will highlight the next perspective in the list.
You can also use "ctrl-shift-8", which does "Previous Perspective", to cycle through the list in the other direction.
Re: Stop debugging [message #540668 is a reply to message #540373] Wed, 16 June 2010 22:33 Go to previous message
Am 15.06.2010 22:53, schrieb David M. Karr:
Thanks David, I didn't know about the "Ctrl-f8" shortcut but I would be
happy if that happened automatically.
Hans
Previous Topic:convert files from windows to linux
Next Topic:Editing batch files
Current Time: Sat Apr 21 06:11:33 GMT 2018
Powered by FUDForum. Page generated in 0.03135 seconds
