Home » Language IDEs » C / C++ IDE (CDT) » Run/Debug settings
Run/Debug settings [message #539894] Mon, 14 June 2010 08:50 Go to next message
No real name is currently offline No real nameFriend
Can you help me please? I copied one of my projects to another directory (source files, makefiles, .cproject, .project files, /.settings folder). After it I imported the project from the new location, but I recognized that the run/debug settings that were present have disappeared.
Are they stored somewhere else? When I imported the project from its older location, its run/debug settings also disappeared.
If I remove the projects from the workspace, the run/debug settings disappear?
Also, I don't know if there are any other project properties that can disappear if I move a project into another directory?
recortebordes
Re: Run/Debug settings [message #540004 is a reply to message #539894] Mon, 14 June 2010 14:54 Go to previous messageGo to next message
Axel Mueller is currently offline Axel MuellerFriend
The run/debug configurations are stored in the workspace. You can export/import them: File->Import...
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Re: Run/Debug settings [message #540791 is a reply to message #540004] Thu, 17 June 2010 11:34 Go to previous message
Thank you very much
Previous Topic:Compiler setup
Next Topic:a very n00b question...
Current Time: Mon Jun 25 04:43:56 GMT 2018
Powered by FUDForum. Page generated in 0.01839 seconds
