Home » Eclipse Projects » Eclipse Platform » Change eclipse workspace programmatically(How to change eclipse workspace (similar to switch workspace in IDE) programmatically?)
Change eclipse workspace programmatically [message #539639] Fri, 11 June 2010 15:03 Go to next message
Raja Kannappan is currently offline Raja KannappanFriend
We have an eclipse RCP application and we would like to set the default eclipse working directory to user home directory (right now the default is current directory)
I understand that I can do this using -data option. But, I see that it does not work when I put this option in .ini file. It only works when I pass it as an option in command line to .exe file.
Also, is there a way to set this option programmatically?
Thanks in advance,
- Raja.
[Updated on: Fri, 11 June 2010 15:04]
Report message to a moderator
Re: Change eclipse workspace programmatically [message #539676 is a reply to message #539639] Fri, 11 June 2010 19:59 Go to previous messageGo to next message
Andrew Niefer is currently offline Andrew NieferFriend
"-data" should work in the eclipse.ini file, make sure to place the argument
on the next line:
-data
/path/to/workspace
It is also possible to put it in the config.ini:
osgi.instance.area=/path/to/workspace
> current directory)
> Thanks in advance,
> - Raja.
Re: Change eclipse workspace programmatically [message #539679 is a reply to message #539676] Fri, 11 June 2010 20:13 Go to previous messageGo to next message
Yes. It works when I put it in the next line. I initially put it in the same line and it did not like it.
I would like to set it to user's home directory and not hard code the location. That's why I was wondering if there is a way to set this programmatically. Or, is there a way to point data location to user home directory from ini file?
Thanks.
Re: Change eclipse workspace programmatically [message #539710 is a reply to message #539679] Sat, 12 June 2010 01:34 Go to previous message
Found how to point workspace to user home directory:
-data
@user.home
The above works.
Previous Topic:How to get texts inside Shell
Next Topic:The program 'Eclipse' received an X Window System error.
Current Time: Fri Jan 19 02:04:39 GMT 2018
Powered by FUDForum. Page generated in 0.01776 seconds
