Re: adding action to the context menu of UML2Tools plugin [message #539904 is a reply to message #539255] |
Mon, 14 June 2010 09:10 |
Originally posted by: formatzeh.gmx.de
open the desired editor and press ctrl+shift+F1 and the plugin spy gives
you the active menu contribution identifier for the UMLTools class
diagram editor:
org.eclipse.gmf.runtime.diagram.ui.DiagramEditorContextMenu
best regards
deepalijayantjoshi@gmail.com wrote:
> I have to add action to the context menu of UML2Tools editor for class
> diagram and sequence diagram.What is the target id for object contribution?
> Could anyone guide me please.
Re: adding action to the context menu of UML2Tools plugin [message #541097 is a reply to message #541058] |
Fri, 18 June 2010 10:22 |
what about right-clicking the file and invoke "open with..."? There you
can choose a text editor or at least an xml editor. If that's not the
solution I don't understand your problem.
best regards,
Gilbert
> Thanks a lot for your guidance.
> I have another query.
> I want to open an file .umlclass in Eclipse as a text file .How will I
> able to do it?Do I need to study EFS for it or it is possible through
> java file handling?
> Please Help!
> Deepali
Re: adding action to the context menu of UML2Tools plugin [message #625645 is a reply to message #625644] |
best regards,
Gilbert
> java file handling?
> Please Help!
> Deepali
FUDForum. Page generated in 0.03489 seconds
