Home » Eclipse Projects » JFace » Can't make JFace TreeViewer larger
Can't make JFace TreeViewer larger [message #538865] Tue, 08 June 2010 20:13 Go to next message
Simon is currently offline SimonFriend
I want to create a JFace TreeViewer in a JFace WizardPage. My problem is that the viewer is too small.
I tried to extend the viewer over two columns of a GridLayout but it doesn't work. The viewer always has the same
size.
public class FileSelectionPage extends WizardPage implements ISelectionChangedListener {
public void createControl(Composite parent) {
Composite composite = new Composite(parent, SWT.NONE);
gl.numColumns = 2;
composite.setLayout(gl);
Label label = new Label(composite, SWT.NONE);
label.setText("Please select an axl file: ");
Label dummyLabel2 = new Label(composite, SWT.NONE);
dummyLabel2.setText(" ");
TreeViewer viewer = new TreeViewer(composite,SWT.BORDER);
viewer.setContentProvider(new FileTreeContentProvider());
viewer.setLabelProvider(new FileTreeLabelProvider());
File[] fileSystemRoots = File.listRoots();
viewer.setInput(fileSystemRoots);
viewer.addSelectionChangedListener(this);
GridData viewerGridData = new GridData();
viewerGridData.horizontalSpan = 2;
viewer.getControl().setLayoutData(viewerGridData);
setControl(composite);
//setControl(parent);
best regards
Simon
Re: Can't make JFace TreeViewer larger [message #538873 is a reply to message #538865] Tue, 08 June 2010 20:33 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
You need to tell GridData to use the complete space available.
Tom
Am 08.06.10 22:13, schrieb Simon:
> Hello,
> size.
> gl.numColumns = 2;
GridData viewerGridData = new GridData(GridData.FILL_BOTH)
> best regards
> Simon
Re: Can't make JFace TreeViewer larger [message #539442 is a reply to message #538873] Thu, 10 June 2010 17:54 Go to previous message
Thank you Tom. It now works correctly.
best regards
Simon
Previous Topic:[Fwd: Removing columns from viewers]
Next Topic:ButtonCellEditor
Current Time: Fri May 25 17:00:53 GMT 2018
Powered by FUDForum. Page generated in 0.01707 seconds
