Home » Modeling » EMF » Internal structure of java method
Internal structure of java method [message #538484] Mon, 07 June 2010 17:59 Go to next message
Alexey  is currently offline Alexey Friend
Member
Hi, all (and Ed in particular)
I am looking for some way, other than annotations, to specify internal structure of java method (EOperation). In the article http://www.ibm.com/developerworks/library/os-eclipse-emfmeta model/index.html (Generating concrete, reusable Java snippets), Ken McNeill shows one way. Which is creation of a metamodel (an extension of http://www.eclipse.org/emf/2002/Ecore) that adds something "EOperationX" that is actually an EClass (that extends EOperation). Then Ken uses EReference inside that EClass to model fragments of code. That approach seems to me a bit artificial, in other words, unnatural. EMF itself when it needs to generate some functional java code, using the trick which only works for ... EMF itself. I see it this way: EMF contains number of internally implemented services: persistence, notification, elements of validation, that capable of doing some very much predefined work. And then, using fixed (not extendable) metadata on eCore object, EMF generates delegation calls to those services. It works in a very narrow frame. May be enough for Eclipse internal needs and EMF specific object model, but that's it. I am interested in ability to generate code which is not so much restricted by EMF object and services model. In particularly, to express internal structure of (java) methods, at least in term of (unconditional) invocation from open set of "external" services: specify service element (by name) and set of actual invocation parameters. I believe that annotation construct is not a proper solution for such a problem.
So, is something in EMF that can help? Ken McNeill in the article given above had shown one way. Is there anything else more direct and natural for EMF?
Re: Internal structure of java method [message #538560 is a reply to message #538484] Tue, 08 June 2010 00:14 Go to previous messageGo to next message
--------------030203080708040101050205
Content-Type: text/plain; charset=UTF-8; format=flowed
Alexey,
Comments below.
Why?
> natural for EMF?
This release we added the ability to define behavior using pluggable
scripting language support:
http://wiki.eclipse.org/EMF/New_and_Noteworthy/Helios#Suppor t_for_Operation_Invocation_Delegates
It still uses annotations.
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Alexey,<br>
<br>
Comments below.<br>
<br>
<br>
Alexey wrote:
<blockquote cite="mid:hujc1f$hov$1@build.eclipse.org" type="cite">Hi,
<br>
<br>
<a class="moz-txt-link-freetext" href=" http://www.ibm.com/developerworks/library/os-eclipse-emfmeta model/index.html"> http://www.ibm.com/developerworks/library/os-eclipse-emfmeta model/index.html</a>
<a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/2002/Ecore">http://www.eclipse.org/emf/2002/Ecore</a>) that adds something
<br>
</blockquote>
Why?<br>
<blockquote cite="mid:hujc1f$hov$1@build.eclipse.org" type="cite">So,
for EMF? <br>
</blockquote>
scripting language support:<br>
<blockquote><a
href=" http://wiki.eclipse.org/EMF/New_and_Noteworthy/Helios#Suppor t_for_Operation_Invocation_Delegates"> http://wiki.eclipse.org/EMF/New_and_Noteworthy/Helios#Suppor t_for_Operation_Invocation_Delegates</a><br>
</blockquote>
It still uses annotations.<br>
<br>
</body>
</html>
--------------030203080708040101050205--
Re: Internal structure of java method [message #538773 is a reply to message #538484] Tue, 08 June 2010 15:27 Go to previous messageGo to next message
Member
Ed,
thanks for answering. The topic "Support for Operation Invocation Delegates" seems interesting. I will read it all carefully. When "Milestone 4" can be available? What means "this release"?
I think annotation mechanism is not appropriate to specify the internal structure of operatios, because annotations are obviously external objects, attached to operation. If you even try to express the simple sequence of invocations (delegations), even then you need to map in your mind externally described sequence into operation. It's just not a right way to do things, not structural, not along with MDA or OO culture. At least that is how I see it
I believe the better way - to add Delegation element as child to Operation. Allow to construct parameters of delegation from parameters of operation. As next step, allow to add DecisionMaking elements chile element to operation. And then, allow recursive CodeBlocks construct inside operation, consisting from other CodeBlock, DecisionMaking and Delegation elements...At least that is about how I see it. In some sence, it would mean extending EMF with some form of activities and appropriate diagrams, digesting next piece of UML.
Well, may be you have different and better vision how EMF should progress, but that (your better vision) seems not available for outsiders....
Alexey
Re: Internal structure of java method [message #538789 is a reply to message #538773] Tue, 08 June 2010 15:51 Go to previous messageGo to next message
Alexey,
Comments below.
Alexey wrote:
> Ed,
This is part of the Helios coordinated release.
EMF 2.6 which releases with Eclipse 3.6 as part of Helios the last week
of June.
They're contained objects so I'm not sure what you're implying by the
word "external".
Even in Java, an operation body is effectively some text contained
within curly braces. In a textual representation of Ecore, e.g.,
Emfatic, it would appear the same way.
> Operation.
Annotations are contained children.
So you're talking about an entire structurally modeled abstract syntax
tree for a statement and expression language. That's also possible, but
we're not in the "business" of defining yet another Turing complete
programming language. It's an interest possibility though.
As it stands, people acan and have plugged in support for OCL and
Javascript.
> outsiders....
Eclipse modeling is like a layered and I see description of behavior as
something others should be able to add as an additional layer rather
than something that should be fundamentally dictated by a single
implementation in the EMF core itself.
> Thanks
> Alexey
Re: Internal structure of java method [message #538983 is a reply to message #538484] Wed, 09 June 2010 09:11 Go to previous message
Originally posted by: formatzeh.gmx.de
Hi Alexey,
another solution is eJava [1]. With eJava you can specify your
operations bodies seperately in an own file. It really feels like normal
java except very few new keywords. You can import normal Java
dependencies and other model elements as well. Then a builder generates
the resulting code as annotation in the ecore file. The advantage is
that depending on the properties of the genmodel the right code will be
generated. For example you can use a term like '#YourMetaClass' as a
placeholder for the creation of a new instance of the class
YourMetaClass. If the use of a factory is defined in the genmodel it
will be translated to this factory. I can really recommend eJava.
best regards,
Gilbert
[1] http://www.emftext.org/index.php/EMFText_Concrete_Syntax_Zoo _eJava
Previous Topic:Issues with EMF Generics
Next Topic:[CDO] Problem with CDOStore.contains()
Current Time: Tue May 22 08:30:15 GMT 2018
Powered by FUDForum. Page generated in 0.01874 seconds
