Re: prey-predator [message #537018 is a reply to message #537004] |
Mon, 31 May 2010 23:51   |
Miles Parker Messages: 1341 Registered: July 2009 |
Hi Jean-Paul,
Jean-Paul de Vooght wrote on Mon, 31 May 2010 16:36 | Hi all! Hi Miles!
I am slowly getting through a basic prey-predator model which is far from completion yet. But it's fun to construct when I compare to other environments.
That's good to know! It sounds silly, but I think if we get that part right then that is one of the important things. After all, there are lot's of ABM frameworks out there that you can get a lot done -- functionality is important but you need to be able to play.
Quote: | I am getting an "HostCell not available" error which I believe is due to the logic of searching for free space to move both my Prey and Predator agents. But I'm not certain.
Thanks for the model. So a few things:
1. Actually, it took me a while to puzzle things out, then I remembered a comment someone else made that they had confused Evaluate actions for Query actions. And indeed you had Evaluate where you needed a Query. So I fixed that.
2. For the selections, you want to be searching for the target of whatever command you are using. So in most cases for moving around on a lattice -- except for the special case of where you're searching for prey -- that will mean that you want to put the habitat cell there. But actually you don't need the habitat cell at all anymore, so you could also get rid of that and leave "agent" blank.
3. There is actually an error in the generated code. For now, please go to the PredatorAgent.java and comment out the following code:
public void predatorAgentRule() {
// if (getHostScape() != ((Agent) predatorAgent).getScape()) {
// die();
// getPreyPredator().getPredatorAgentScape().add(this);
moveToward(((org.ascape.model.CellOccupant) predatorAgent)
.getHostCell());
Quote: | One thing I am not sure I fully grasp is the importance of order in the targets. I ask because looking at the StupidModels and eventually thinking of GAS/Sugarscape, there's a certain order to respect - or not?
If I'm understanding what you're saying right, then yes, the order is critical -- it's what defines what selection feeds into the next.
I have to run so I can't post it somewhere else, but hopefully just putting the xml code in a code block here will allow you to copy it.. (And for folks following this thread -- no, you're not supposed to edit this directly!)
<metaabm:SContext xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:act="http://metaabm.org/act" xmlns:function="http://metaabm.org/function" xmlns:metaabm="http://metaabm.org/structure" label="PreyPredator" ID="preyPredator" pluralLabel="PreyPredators">
<attributes label="Prey Agent Count" ID="preyAgentCount" pluralLabel="Prey Agent Counts" description="The number of prey agents to create." gatherData="true" defaultValue="100"/>
<attributes label="Predator Agent Count" ID="predatorAgentCount" pluralLabel="Predator Agent Counts" description="The number of predator agents to create." gatherData="true" defaultValue="20"/>
<rootActivity xsi:type="act:AGroup" label="Root Act Group" ID="rootActGroup" pluralLabel="Root Act Groups">
<members xsi:type="act:ABuild" label="Build PreyPredator" ID="buildPreyPredator" targets="//@rootActivity/@members[ID='createPreyAgents'] //@rootActivity/@members[ID='createPredatorAgents'] //@rootActivity/@members[ID='buildGrid2D']" selected="//@rootActivity/@members[ID='buildPreyPredator']" agent="/" pluralLabel="Build PreyPredators"/>
<members xsi:type="act:ACreateAgents" label="Create Prey Agents" ID="createPreyAgents" sources="//@rootActivity/@members[ID='buildPreyPredator']" selected="//@rootActivity/@members[ID='buildPreyPredator']" agent="//@agents[ID='preyAgent']" agentCount="//@attributes[ID='preyAgentCount']"/>
<members xsi:type="act:ACreateAgents" label="Create Predator Agents" ID="createPredatorAgents" sources="//@rootActivity/@members[ID='buildPreyPredator']" selected="//@rootActivity/@members[ID='buildPreyPredator']" agent="//@agents[ID='predatorAgent']" agentCount="//@attributes[ID='predatorAgentCount']"/>
<members xsi:type="act:ABuildGrid" label="Build Grid 2D" ID="buildGrid2D" sources="//@rootActivity/@members[ID='buildPreyPredator']" selected="//@rootActivity/@members[ID='buildPreyPredator']" pluralLabel="Build Grid 2Ds" agents="//@agents[ID='predatorAgent'] //@agents[ID='preyAgent']" projection="//@projections[ID='grid2D']" fillAgent="//@agents[ID='habitat']"/>
</rootActivity>
<implementation package="preypredator" className="PreyPredator" basePath=""/>
<agents label="Prey Agent" ID="preyAgent" pluralLabel="Prey Agents">
<members xsi:type="act:AInitialize" label="Initialize" ID="initialize" targets="//@agents[ID='preyAgent']/@rootActivity/@members[ID='randomHabitat']" selected="//@agents[ID='preyAgent']/@rootActivity/@members[ID='initialize']" agent="//@agents[ID='preyAgent']" space="//@projections[ID='grid2D']" pluralLabel="Initializes"/>
<members xsi:type="act:ASelect" label="Random Habitat" ID="randomHabitat" sources="//@agents[ID='preyAgent']/@rootActivity/@members[ID='initialize']" targets="//@agents[ID='preyAgent']/@rootActivity/@members[ID='randomHabitatAvailable']" selected="//@agents[ID='preyAgent']/@rootActivity/@members[ID='initialize']" agent="//@agents[ID='habitat']" space="//@projections[ID='grid2D']"/>
<members xsi:type="act:AQuery" label="Random Habitat: Available()" ID="randomHabitatAvailable" sources="//@agents[ID='preyAgent']/@rootActivity/@members[ID='randomHabitat']" targets="//@agents[ID='preyAgent']/@rootActivity/@members[ID='movePreyAgent']" selected="//@agents[ID='preyAgent']/@rootActivity/@members[ID='randomHabitat']">
<function xsi:type="function:FGenericLogical" href="http://metaabm.org/core_library.metaabm#//@library[ID='coreFunctions']/@subs[ID='spatial']/@functions[ID='available']"/>
</members>
<members xsi:type="act:AMove" label="Move Prey Agent" ID="movePreyAgent" sources="//@agents[ID='preyAgent']/@rootActivity/@members[ID='randomHabitatAvailable']" selected="//@agents[ID='preyAgent']/@rootActivity/@members[ID='initialize']" destination="//@agents[ID='preyAgent']/@rootActivity/@members[ID='randomHabitat']"/>
</rootActivity>
<implementation className="PreyAgent"/>
<styles xsi:type="metaabm:SStyle2D" label="Prey Agent Style 2D" ID="preyAgentStyle2D" pluralLabel="Prey Agent Style 2Ds">
<members xsi:type="act:ARule" label="Prey Agent Rule" ID="preyAgentRule" targets="//@agents[ID='preyAgent']/@styles[ID='preyAgentStyle2D']/@rootActivity/@members[ID='preyAgentRuleColorBlue']" selected="//@agents[ID='preyAgent']/@styles[ID='preyAgentStyle2D']/@rootActivity/@members[ID='preyAgentRule']" agent="//@agents[ID='preyAgent']" space="//@projections[ID='grid2D']" pluralLabel="Prey Agent Rules"/>
<members xsi:type="act:AEvaluate" label="Prey Agent Rule: Color Blue()" ID="preyAgentRuleColorBlue" sources="//@agents[ID='preyAgent']/@styles[ID='preyAgentStyle2D']/@rootActivity/@members[ID='preyAgentRule']" targets="//@agents[ID='preyAgent']/@styles[ID='preyAgentStyle2D']/@rootActivity/@members[ID='preyAgentRuleShapeOval']" selected="//@agents[ID='preyAgent']/@styles[ID='preyAgentStyle2D']/@rootActivity/@members[ID='preyAgentRule']">
<function xsi:type="function:FGenericFunction" href="http://metaabm.org/core_library.metaabm#//@library[ID='coreFunctions']/@subs[ID='graphic']/@functions[ID='colorBlue']"/>
</members>
<members xsi:type="act:AEvaluate" label="Prey Agent Rule: Shape Oval()" ID="preyAgentRuleShapeOval" sources="//@agents[ID='preyAgent']/@styles[ID='preyAgentStyle2D']/@rootActivity/@members[ID='preyAgentRuleColorBlue']" targets="//@agents[ID='preyAgent']/@styles[ID='preyAgentStyle2D']/@rootActivity/@members[ID='preyAgentRuleShapeMarker']" selected="//@agents[ID='preyAgent']/@styles[ID='preyAgentStyle2D']/@rootActivity/@members[ID='preyAgentRule']">
<function xsi:type="function:FGenericFunction" href="http://metaabm.org/core_library.metaabm#//@library[ID='coreFunctions']/@subs[ID='graphic']/@functions[ID='shapeOval']"/>
</members>
<members xsi:type="act:AEvaluate" label="Prey Agent Rule: Shape Marker()" ID="preyAgentRuleShapeMarker" sources="//@agents[ID='preyAgent']/@styles[ID='preyAgentStyle2D']/@rootActivity/@members[ID='preyAgentRuleShapeOval']" selected="//@agents[ID='preyAgent']/@styles[ID='preyAgentStyle2D']/@rootActivity/@members[ID='preyAgentRule']">
<function xsi:type="function:FGenericFunction" href="http://metaabm.org/core_library.metaabm#//@library[ID='coreFunctions']/@subs[ID='graphic']/@functions[ID='graphicFill']"/>
</members>
</rootActivity>
<implementation className="PreyAgentStyle2D"/>
</styles>
</agents>
<agents label="Predator Agent" ID="predatorAgent" pluralLabel="Predator Agents">
<members xsi:type="act:AInitialize" label="Initialize" ID="initialize" targets="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='randomHabitat']" selected="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='initialize']" agent="//@agents[ID='predatorAgent']" space="//@projections[ID='grid2D']" pluralLabel="Initializes"/>
<members xsi:type="act:ASelect" label="Random Habitat" ID="randomHabitat" sources="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='initialize']" targets="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='randomHabitatAvailable']" selected="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='initialize']" agent="//@agents[ID='habitat']" space="//@projections[ID='grid2D']"/>
<members xsi:type="act:AQuery" label="Random Habitat: Available()" ID="randomHabitatAvailable" sources="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='randomHabitat']" targets="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='movePredatorAgent']" selected="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='randomHabitat']">
</members>
<members xsi:type="act:AMove" label="Move Predator Agent" ID="movePredatorAgent" sources="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='randomHabitatAvailable']" selected="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='initialize']" destination="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='randomHabitat']"/>
<members xsi:type="act:ARule" label="Predator Agent Rule" ID="predatorAgentRule" targets="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='predatorAgent']" selected="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='predatorAgentRule']" agent="//@agents[ID='predatorAgent']" space="//@projections[ID='grid2D']" pluralLabel="Predator Agent Rules"/>
<members xsi:type="act:ASelect" label="Predator Agent" ID="predatorAgent" sources="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='predatorAgentRule']" targets="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='nearestQuery'] //@agents[ID='predatorAgent']/@rootActivity/@members[ID='towardQuery']" selected="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='predatorAgentRule']" agent="//@agents[ID='predatorAgent']" space="//@projections[ID='grid2D']"/>
<members xsi:type="act:AQuery" label="Nearest () Query" ID="nearestQuery" sources="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='predatorAgent']" targets="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='_NearestQueryAndTowardQueryAndAvailableQuery_']" selected="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='predatorAgent']">
<function xsi:type="function:FGenericLogical" href="http://metaabm.org/core_library.metaabm#//@library[ID='coreFunctions']/@subs[ID='spatial']/@functions[ID='nearest']"/>
</members>
<members xsi:type="act:AQuery" label="Toward() Query" ID="towardQuery" sources="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='predatorAgent']" targets="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='_NearestQueryAndTowardQueryAndAvailableQuery_']" selected="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='predatorAgent']">
<function xsi:type="function:FGenericLogical" href="http://metaabm.org/core_library.metaabm#//@library[ID='coreFunctions']/@subs[ID='spatial']/@functions[ID='toward']"/>
</members>
<members xsi:type="act:AAll" label="(Nearest () Query & Toward() Query & Available() Query)" ID="_NearestQueryAndTowardQueryAndAvailableQuery_" sources="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='towardQuery'] //@agents[ID='predatorAgent']/@rootActivity/@members[ID='nearestQuery']" targets="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='movePredatorAgentCopy']" selected="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='predatorAgent']"/>
<members xsi:type="act:AMove" label="Move Predator Agent Copy" ID="movePredatorAgentCopy" sources="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='_NearestQueryAndTowardQueryAndAvailableQuery_']" selected="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='predatorAgentRule']" destination="//@agents[ID='predatorAgent']/@rootActivity/@members[ID='predatorAgent']"/>
</rootActivity>
<implementation className="PredatorAgent"/>
<styles xsi:type="metaabm:SStyle2D" label="Predator Agent Style 2D" ID="predatorAgentStyle2D" pluralLabel="Predator Agent Style 2Ds">
<members xsi:type="act:ARule" label="Predator Agent Rule" ID="predatorAgentRule" targets="//@agents[ID='predatorAgent']/@styles[ID='predatorAgentStyle2D']/@rootActivity/@members[ID='predatorAgentRuleColorRed']" selected="//@agents[ID='predatorAgent']/@styles[ID='predatorAgentStyle2D']/@rootActivity/@members[ID='predatorAgentRule']" agent="//@agents[ID='predatorAgent']" space="//@projections[ID='grid2D']" pluralLabel="Predator Agent Rules"/>
<members xsi:type="act:AEvaluate" label="Predator Agent Rule: Color Red()" ID="predatorAgentRuleColorRed" sources="//@agents[ID='predatorAgent']/@styles[ID='predatorAgentStyle2D']/@rootActivity/@members[ID='predatorAgentRule']" targets="//@agents[ID='predatorAgent']/@styles[ID='predatorAgentStyle2D']/@rootActivity/@members[ID='predatorAgentRuleShapeOval']" selected="//@agents[ID='predatorAgent']/@styles[ID='predatorAgentStyle2D']/@rootActivity/@members[ID='predatorAgentRule']">
<function xsi:type="function:FGenericFunction" href="http://metaabm.org/core_library.metaabm#//@library[ID='coreFunctions']/@subs[ID='graphic']/@functions[ID='colorRed']"/>
</members>
<members xsi:type="act:AEvaluate" label="Predator Agent Rule: Shape Oval()" ID="predatorAgentRuleShapeOval" sources="//@agents[ID='predatorAgent']/@styles[ID='predatorAgentStyle2D']/@rootActivity/@members[ID='predatorAgentRuleColorRed']" targets="//@agents[ID='predatorAgent']/@styles[ID='predatorAgentStyle2D']/@rootActivity/@members[ID='predatorAgentRuleGraphicFill']" selected="//@agents[ID='predatorAgent']/@styles[ID='predatorAgentStyle2D']/@rootActivity/@members[ID='predatorAgentRule']">
</members>
<members xsi:type="act:AEvaluate" label="Predator Agent Rule: Graphic Fill()" ID="predatorAgentRuleGraphicFill" sources="//@agents[ID='predatorAgent']/@styles[ID='predatorAgentStyle2D']/@rootActivity/@members[ID='predatorAgentRuleShapeOval']" selected="//@agents[ID='predatorAgent']/@styles[ID='predatorAgentStyle2D']/@rootActivity/@members[ID='predatorAgentRule']">
</members>
</rootActivity>
<implementation className="PredatorAgentStyle2D"/>
</styles>
</agents>
<agents label="Habitat" ID="habitat" pluralLabel="Habitats">
<rootActivity xsi:type="act:AGroup" label="Root Act Group" ID="rootActGroup" pluralLabel="Root Act Groups"/>
<implementation className="Habitat"/>
<styles xsi:type="metaabm:SStyle2D" label="Habitat Style 2D" ID="habitatStyle2D" pluralLabel="Habitat Style 2Ds">
<members xsi:type="act:ARule" label="Habitat Rule" ID="habitatRule" targets="//@agents[ID='habitat']/@styles[ID='habitatStyle2D']/@rootActivity/@members[ID='habitatRuleColorGreen']" selected="//@agents[ID='habitat']/@styles[ID='habitatStyle2D']/@rootActivity/@members[ID='habitatRule']" agent="//@agents[ID='habitat']" space="//@projections[ID='grid2D']" pluralLabel="Habitat Rules"/>
<members xsi:type="act:AEvaluate" label="Habitat Rule: Color Green()" ID="habitatRuleColorGreen" sources="//@agents[ID='habitat']/@styles[ID='habitatStyle2D']/@rootActivity/@members[ID='habitatRule']" targets="//@agents[ID='habitat']/@styles[ID='habitatStyle2D']/@rootActivity/@members[ID='habitatRuleShapeRectangle']" selected="//@agents[ID='habitat']/@styles[ID='habitatStyle2D']/@rootActivity/@members[ID='habitatRule']">
<function xsi:type="function:FGenericFunction" href="http://metaabm.org/core_library.metaabm#//@library[ID='coreFunctions']/@subs[ID='graphic']/@functions[ID='colorGreen']"/>
</members>
<members xsi:type="act:AEvaluate" label="Habitat Rule: Shape Rectangle()" ID="habitatRuleShapeRectangle" sources="//@agents[ID='habitat']/@styles[ID='habitatStyle2D']/@rootActivity/@members[ID='habitatRuleColorGreen']" targets="//@agents[ID='habitat']/@styles[ID='habitatStyle2D']/@rootActivity/@members[ID='habitatRuleGraphicFill']" selected="//@agents[ID='habitat']/@styles[ID='habitatStyle2D']/@rootActivity/@members[ID='habitatRule']">
<function xsi:type="function:FGenericFunction" href="http://metaabm.org/core_library.metaabm#//@library[ID='coreFunctions']/@subs[ID='graphic']/@functions[ID='shapeRectangle']"/>
</members>
<members xsi:type="act:AEvaluate" label="Habitat Rule: Graphic Fill()" ID="habitatRuleGraphicFill" sources="//@agents[ID='habitat']/@styles[ID='habitatStyle2D']/@rootActivity/@members[ID='habitatRuleShapeRectangle']" selected="//@agents[ID='habitat']/@styles[ID='habitatStyle2D']/@rootActivity/@members[ID='habitatRule']">
</members>
</rootActivity>
<implementation className="HabitatStyle2D"/>
</styles>
</agents>
<projections xsi:type="metaabm:SGrid" label="Grid 2D" ID="grid2D" pluralLabel="Grid 2Ds" dimensionality="2" borderRule="PERIODIC">
<attributes xsi:type="metaabm:SAttributeArray" label="Dimensions" ID="dimensions" pluralLabel="Dimensionss" description="The size of each dimension." size="2"/>
<attributes label="Width" ID="width" pluralLabel="Widths" description="The horizontal extent of the space." defaultValue="100"/>
<attributes label="Height" ID="height" pluralLabel="Heights" description="The vertical extent of the space." defaultValue="100"/>
</projections>
</metaabm:SContext>
Re: prey-predator [message #538130 is a reply to message #537298] |
Sat, 05 June 2010 13:26   |
Jean-Paul de Vooght Messages: 20 Registered: April 2010 |
Junior Member |
Ok so back to PreyPredator with the new 0.7.0 codebase.
I noticed some changes such as RootGroups disappeared from Styles as well as Dimensions on Grids. I like this because it makes things simpler.
I have tried to re-build it from bottom up and hit this exception
java.lang.NoClassDefFoundError: Could not initialize class org.eclipse.xtend.expression.ExecutionContextImpl
at org.eclipse.xtend.XtendFacade.create(XtendFacade.java:53)
at org.eclipse.amp.amf.gen.ide.ModelMarkerHelper.<init>(ModelMarkerHelper.java:50)
at org.eclipse.amp.amf.gen.ide.AbstractMWEBuilder.generateModel(AbstractMWEBuilder.java:142)
at org.eclipse.amp.amf.gen.ide.AbstractMWEBuilder.handleModifiedResource(AbstractMWEBuilder.java:184)
at org.eclipse.amp.escape.amf.ide.GenerateEscapeHandler.execute(GenerateEscapeHandler.java:26)
at org.eclipse.amp.amf.gen.ide.ResourceHandler.execute(ResourceHandler.java:68)
at org.eclipse.amp.amf.gen.ide.ResourceHandler.executeHandler(ResourceHandler.java:72)
at org.eclipse.amp.amf.gen.ide.ResourceJobHandler.access$0(ResourceJobHandler.java:1)
at org.eclipse.amp.amf.gen.ide.ResourceJobHandler$1.run(ResourceJobHandler.java:40)
Any ideas on how to fix this one?
I have installed Xtend core, UI, UML2 typesystem, XSD typesystem 1.0.0.v201006010440
I also noticed that the indentation logic changed: evaluations are shown one below the other instead of indendented - is this correct?
TIA
[Updated on: Sat, 05 June 2010 13:59] Report message to a moderator
FUDForum. Page generated in 0.02247 seconds
