Home » Language IDEs » C / C++ IDE (CDT) » Unable to build project with jam (or make)
Unable to build project with jam (or make) [message #536659] Sat, 29 May 2010 12:55 Go to next message
salvatore  is currently offline salvatore Friend
I'm trying to use eclipse-cdt to cross-compile a project that uses jam as build system.
I managed to import the project through the SVN plugin, but I'm unable to build the project.
From the project properties I unchecked the "use default build command" option, and replaced with jam. I also unchecked the "Generates makefile automatically".
When I try to build system I get.
(Cannot run program "jam": Unknown reason)
but jam is correctly install
emitrax@xartimequad:~$ jam -v
Jam 2.5-haiku-20090626. OS=LINUX. Copyright 1993-2002 Christopher Seiwald.
emitrax@xartimequad:~$ which jam
/usr/local/bin/jam
and the path of the binary is in the PATH variable of the eclipse enviroment
Project -> Properties -> C/C++ build -> environment
PATH:  /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/bin/
I googled a bit and someone suggest to disable the "use parallel build option", but it didn't solve my problem.
I also tried to replace jam with the make command to see if the message would be different, but I still get the useless "Cannot run program "jam": Unknown reason" message.
Any idea how to solve this?
Thanks in advance.
S.
Re: Unable to build project with jam (or make) [message #537043 is a reply to message #536659] Tue, 01 June 2010 07:26 Go to previous messageGo to next message
Axel Mueller is currently offline Axel MuellerFriend
Does jam need any special shared libs that it cannot find when started within Eclipse? Can you check your LD_LIBRARY_PATH (or ldd jam)?
That is weird. Are you sure that you substituted jam with the make command only in Project Properties->C/C++ Build "build command"? Can you grep for jam in your .cproject file (it is hidden in the project folder)?
BTW, which Eclipse/CDT version are you using?
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Re: Unable to build project with jam (or make) [message #537048 is a reply to message #537043] Tue, 01 June 2010 07:41 Go to previous messageGo to next message
Axel Mueller wrote on Tue, 01 June 2010 03:26
I will check this tonight when I'll get back to my computer. Thanks.
I'm sorry, this was a copy & paste error. The error I get is "Cannot run program "make": Unknown reason ... ".
which is also weird to me.
I download both eclipse galileo and CDT few days ago, so they should be the lasted version (3.5 and 6.0.2 if I recall correctly).
Any idea?
Thanks again.
Re: Unable to build project with jam (or make) [message #537259 is a reply to message #536659] Tue, 01 June 2010 17:34 Go to previous message
And so it worked!
I went to check the dependencies as you suggested and he gave me a weird "no permission error". Weird because apparently it got installed with the execution permission but not the reading one.
A simple chmod +r to the binary fixed my problem.
Thanks again.
S.
Previous Topic:Eclipse CDT Linux makefile
Next Topic:getIndex
Current Time: Tue Feb 20 07:55:15 GMT 2018
Powered by FUDForum. Page generated in 0.02947 seconds
