Home » Eclipse Projects » Buckminster » Groovy support, Eclipse 3.6
Groovy support, Eclipse 3.6 [message #536287] Thu, 27 May 2010 14:24 Go to next message
Geejay is currently offline GeejayFriend
Hello people
I was wondering what the state is at the moment regarding Groovy compilation
within a headless Buckminster?
If it is possible, will I need to migrate my RCP app to Eclipse 3.6, and be
using Buckminster 3.6 in order to setup an automated headless build with
components that are written in Groovy?
"Old" Greg
Re: Groovy support, Eclipse 3.6 [message #536365 is a reply to message #536287] Thu, 27 May 2010 19:00 Go to previous messageGo to next message
Achim Demelt is currently offline Achim DemeltFriend
Hi Greg,
It turned out that there are only some UI-dependencies left to fix in the
Groovy-Eclipse plug-ins. Once these are sorted out, Groovy support should be
ready for prime time. To make installation easier, Andrew may provide a
headless feature if he can find the time to do it. But it's also possible to
install individual bundles into Buckminster, so even without that feature
we're good to go once the UI dependencies are fixed. You can follow our
discussion here: http://jira.codehaus.org/browse/GRECLIPSE-716
As to your second question: Your headless Buckminster will definitely have
to be based on 3.6. However, you can still target your RCP app on 3.5.
Achim
geejay wrote:
> Hello people
> compilation within a headless Buckminster?
> be using Buckminster 3.6 in order to setup an automated headless build
> with components that are written in Groovy?
> Thanks
> "Old" Greg
Re: Groovy support, Eclipse 3.6 [message #536479 is a reply to message #536365] Fri, 28 May 2010 12:29 Go to previous messageGo to next message
Greg,
Good news. I just retried installing the Groovy-Eclipse plugins and ran a
few tests. It seems that the UI dependency issues have been resolved. You
can try it out with this command *after* you have performed a regular
Buckminster headless (3.6) install:
../director/director -r
http://dist.codehaus.org/groovy/distributions/greclipse/snap shot/e3.6/ \
-d /path/to/your/buckminster/installation \
-p Buckminster \
-i org.codehaus.groovy \
-i org.eclipse.jdt.core \
-i org.eclipse.jdt.groovy.core \
-i org.codehaus.groovy.eclipse.codebrowsing
With this setup I was able to compile Groovy code simply by invoking the
Buckminster "build" command, which invokes the regular Groovy Eclipse
builder. I could also run a launch config that executes a Groovy script
class' "main()" method. Finally, I could successfully run Groovy JUnit
tests.
Achim
Achim Demelt wrote:
> Hi Greg,
> be ready for prime time. To make installation easier, Andrew may provide a
> to install individual bundles into Buckminster, so even without that
> feature we're good to go once the UI dependencies are fixed. You can
> follow our discussion here: http://jira.codehaus.org/browse/GRECLIPSE-716
> Achim
> geejay wrote:
>> Hello people
>> Thanks
>> "Old" Greg
Re: Groovy support, Eclipse 3.6 [message #543198 is a reply to message #536479] Mon, 28 June 2010 16:33 Go to previous message
Works like a charm.
Greg
"Achim Demelt" <a.demelt@exxcellent.de> wrote in message
news:htodju$5ra$1@build.eclipse.org...
> Greg,
> -p Buckminster \
> tests.
> Cheers,
> Achim
> Achim Demelt wrote:
>> Hi Greg,
>> a
>> have
>> Achim
>> geejay wrote:
>>> Hello people
>>> Thanks
>>> "Old" Greg
Previous Topic:Project materialization with firing code from other (not Buckminster) plugins
Next Topic:about.mappins and Buckminster 3.6
Current Time: Tue May 22 12:11:26 GMT 2018
Powered by FUDForum. Page generated in 0.01992 seconds
