Home » Modeling » EMF » [Teneo] Adding dynamic objects to resource
[Teneo] Adding dynamic objects to resource [message #536192] Thu, 27 May 2010 10:37 Go to next message
Aleksander Bandelj is currently offline Aleksander BandeljFriend
Member
Latest Teneo HEAD: dynamic objects work fine until I try add them to
hibernate resource contents. Should this work, is there a test case for
such scenario ?
Caused by: org.hibernate.PropertyNotFoundException: Could not find a
getter for id in class org.eclipse.emf.ecore.impl.DynamicEObjectImpl
org.hibernate.property.BasicPropertyAccessor.createGetter(Ba sicPropertyAccessor.java:306)
org.hibernate.property.BasicPropertyAccessor.getGetter(Basic PropertyAccessor.java:299)
at org.hibernate.mapping.Property.getGetter(Property.java:294)
at org.eclipse.emf.teneo.hibernate.HbUtil.idToString(HbUtil.jav a:86)
org.eclipse.emf.teneo.hibernate.resource.HibernateResource.g etURIFragment(HibernateResource.java:277)
org.eclipse.emf.teneo.resource.StoreResource.attachedHelper( StoreResource.java:778)
org.eclipse.emf.teneo.resource.StoreResource.attached(StoreR esource.java:684)
org.eclipse.emf.teneo.resource.StoreResource.setEResource(St oreResource.java:846)
org.eclipse.emf.teneo.resource.StoreResource.addToContent(St oreResource.java:326)
org.eclipse.emf.teneo.resource.StoreResource.load(StoreResou rce.java:306)
at org.mozilla.javascript.MemberBox.invoke(MemberBox.java:155)
... 36 more
Re: [Teneo] Adding dynamic objects to resource [message #536226 is a reply to message #536192] Thu, 27 May 2010 12:38 Go to previous message
Martin Taal is currently offline Martin TaalFriend
Hi Aleksander,
Can you enter a bugzilla for this one?
I could reproduce it and am solving it. Will be in the next build.
gr. Martin
> such scenario ?
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> ... 36 more
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Previous Topic:[Teneo] Problem storing byte[]
Next Topic:[CDO] Saving elements on database
Current Time: Sat Jun 23 20:06:01 GMT 2018
Powered by FUDForum. Page generated in 0.02293 seconds
