Home » Modeling » UML2 » Newbie - Problem creating models
Newbie - Problem creating models [message #535451] Sun, 23 May 2010 17:31 Go to next message
No real name is currently offline No real nameFriend
Hi all
I just started trying to use UML2 in eclipse. I'm following along with the provided tutorial "Getting started with UML2 here:http://www.eclipse.org/modeling/mdt/uml2/docs/articles/ Getting_Started_with_UML2/article.html
In the 'Creating Models' section of the tutorial, step 4 is:
4) Select Model for the model object and press the Finish button
When I select mode, the finish button remains greyed out, and whatever I do remains greyed out. What am I missing?
I'm running eclipse 3.5.2, mac os x, and I installed the software by using the update manager with this link http://download.eclipse.org/modeling/mdt/updates/releases/ . Everything seemed to install fine.
Grateful for any help!
Re: Newbie - Problem creating models [message #535453 is a reply to message #535451] Sun, 23 May 2010 17:49 Go to previous messageGo to next message
Don't worry - I skipped the example wizard and just went straight to the model wizards under 'uml2' and they work fine. Thanks.
Re: Newbie - Problem creating models [message #628453 is a reply to message #535451] Sun, 23 May 2010 17:49 Go to previous message
Previous Topic:Newbie - Problem creating models
Next Topic:Saving an Eclipse UML2 model in an older serialization
Current Time: Mon Apr 23 11:48:25 GMT 2018
Powered by FUDForum. Page generated in 0.01840 seconds
