Home » Eclipse Projects » Virgo » Build Virgo
| Build Virgo [message #534350] |
Tue, 18 May 2010 14:46  |
vollerchris Messages: 23 Registered: July 2009 |
Junior Member |
Hi Virgo-Team!
I am very interessted in testing Virgo!!!!
I am trying to build virgo on my windows system, but build fails:-(!
BUILD FAILED
D:\virgo\org.eclipse.virgo.kernel\virgo-build\multi-bundle\a rtifact.xml:57:
The
following error occurred while executing this line:
D:\virgo\org.eclipse.virgo.kernel\virgo-build\multi-bundle\c ommon.xml:83:
The fo
D:\virgo\org.eclipse.virgo.kernel\virgo-build\common\artifac t.xml:54:
impossible
to publish artifacts for
org.eclipse.virgo.kernel#org.eclipse.virgo.kernel.shut
down;working@grznae368xp: java.io.FileNotFoundException:
rgo.kernel\org.eclipse.virgo.kernel.shutdown\..\integration- repo\org.eclipse.vir
go.kernel\org.eclipse.virgo.kernel.shutdown\2.1.0.BUILD-2010 0518184347.part\org.
eclipse.virgo.kernel.shutdown-2.1.0.BUILD-20100518184347.jar .sha1 (The
filename,
directory name, or volume label syntax is incorrect)
Total time: 4 seconds
D:\virgo\org.eclipse.virgo.kernel\build-kernel>java -version
I am using:
java version "1.6.0_11"
Java(TM) SE Runtime Environment (build 1.6.0_11-b03)
Java HotSpot(TM) Client VM (build 11.0-b16, mixed mode, sharing)
D:\virgo\org.eclipse.virgo.kernel\build-kernel>ant -version
Apache Ant version 1.7.1 compiled on June 27 2008
Please, can you give me a hint?!
Thanks a lot
Chris
| Re: Build Virgo [message #535215 is a reply to message #534636] |
Fri, 21 May 2010 11:22   |
Chris Frost Messages: 222 Registered: January 2010 Location: Southampton, England |
1st, I've learnt I have to manually subscribe to forum posts, I don't automatically notified of new posts, so sorry for the delay.
2nd, it's nothing obvious so I need to go and run the build which I will do next week. Hopefully I'll be able to see what is happening then. If it's an issue with our stuff I'll ask you to raise a bug and we will get on it.
Thanks for getting back to us,
Chris
Chris Frost, Twitter @cgfrost
Springsource, a divison of VMware.
| Re: Build Virgo [message #536540 is a reply to message #534350] |
Fri, 28 May 2010 11:49   |
I have tried this several times now and have it building fine but the tests are failing to start in the userigion. The cause will be Windows specific as it works on other platforms. We need to raise a JIRA issue to address this issue, I would be very grateful if you could do this and then it will get the proper attention. In the mean time you can try dm Server 2.0.2, it is functionally equivalent (http://www.springsource.org/dmserver).
Virgo Bugzilla
Chris
[Updated on: Fri, 28 May 2010 11:50] Report message to a moderator
| Re: Build Virgo [message #537106 is a reply to message #537078] |
Tue, 01 June 2010 07:04   |
Veselin Kovacevic Messages: 12 Registered: April 2010 |
Junior Member |
Hi Chris,
Working perfectly
There was the same problem with VirgoProjectCreationReview PDF file in post Draft docuware for Virgo creation review. Someone should check this issue with eclipse staff.
I'll put kernel log in code tags. Hope that will be properly viewable.
Veso
[2010-05-29 17:28:32.499] startup-tracker org.eclipse.virgo.medic.eventlog.default KE0001I Kernel starting.
[2010-05-29 17:28:40.624] service-monitor-thread-1 org.eclipse.virgo.medic.eventlog.default KE0100W Reference '&deployer' in bundle 'org.eclipse.virgo.kernel.shell' version '2.1.0.BUILD-20100529174554' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.deployer.core.ApplicationDeployer)'.
[2010-05-29 17:28:40.890] service-monitor-thread-1 org.eclipse.virgo.medic.eventlog.default KE0100W Reference '&objectNameCreator' in bundle 'org.eclipse.virgo.kernel.shell' version '2.1.0.BUILD-20100529174554' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.model.management.RuntimeArtifactModelObjectNameCreator)'.
[2010-05-29 17:28:40.890] service-monitor-thread-1 org.eclipse.virgo.medic.eventlog.default KE0100W Reference '&runtimeArtifactModel' in bundle 'org.eclipse.virgo.kernel.model' version '2.1.0.BUILD-20100529174554' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.deployer.model.RuntimeArtifactModel)'.
[2010-05-29 17:28:40.952] service-monitor-thread-1 org.eclipse.virgo.medic.eventlog.default KE0100W Reference '&applicationDeployer' in bundle 'org.eclipse.virgo.kernel.model' version '2.1.0.BUILD-20100529174554' is waiting for service with filter '(objectClass=org.eclipse.virgo.kernel.deployer.core.ApplicationDeployer)'.
[2010-05-29 17:28:41.562] Thread-3 org.eclipse.virgo.medic.eventlog.default KE0101I Reference '&applicationDeployer' in bundle 'org.eclipse.virgo.kernel.model' version '2.1.0.BUILD-20100529174554' was satisfied by service with filter '(objectClass=org.eclipse.virgo.kernel.deployer.core.ApplicationDeployer)'.
[2010-05-29 17:28:41.577] Thread-3 org.eclipse.virgo.medic.eventlog.default KE0101I Reference '&deployer' in bundle 'org.eclipse.virgo.kernel.shell' version '2.1.0.BUILD-20100529174554' was satisfied by service with filter '(objectClass=org.eclipse.virgo.kernel.deployer.core.ApplicationDeployer)'.
[2010-05-29 17:28:42.890] Thread-3 org.eclipse.virgo.medic.eventlog.default KE0101I Reference '&runtimeArtifactModel' in bundle 'org.eclipse.virgo.kernel.model' version '2.1.0.BUILD-20100529174554' was satisfied by service with filter '(objectClass=org.eclipse.virgo.kernel.deployer.model.RuntimeArtifactModel)'.
[2010-05-29 17:28:43.546] Thread-3 org.eclipse.virgo.medic.eventlog.default KE0101I Reference '&objectNameCreator' in bundle 'org.eclipse.virgo.kernel.shell' version '2.1.0.BUILD-20100529174554' was satisfied by service with filter '(objectClass=org.eclipse.virgo.kernel.model.management.RuntimeArtifactModelObjectNameCreator)'.
[2010-05-29 17:28:44.249] kernel-dm-11 org.eclipse.virgo.medic.eventlog.default SH0001I Kernel ssh shell available on port 2401.
[2010-05-29 17:28:44.452] startup-tracker org.eclipse.virgo.medic.eventlog.default KE0002I Kernel started.
[2010-05-29 17:28:44.671] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-05-29 17:28:47.390] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-05-29 17:28:48.202] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-05-29 17:28:48.405] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-05-29 17:28:48.546] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-05-29 17:28:48.624] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-05-29 17:28:55.671] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-05-29 17:28:55.686] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-05-29 17:28:55.702] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-05-29 17:28:55.718] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-05-29 17:28:55.733] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-05-29 17:28:55.733] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-05-29 17:28:55.811] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-05-29 17:28:55.827] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-05-29 17:28:55.874] start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-05-29 17:28:55.889] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-05-29 17:28:57.499] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-05-29 17:28:57.530] start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-05-29 17:28:57.530] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-05-29 17:28:57.577] start-signalling-2 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-05-29 17:28:57.608] start-signalling-2 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-05-29 17:28:57.639] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-05-29 17:28:57.905] start-signalling-2 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-05-29 17:28:57.905] start-signalling-2 org.eclipse.virgo.medic.eventlog.default DE0005I Started plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-05-29 17:28:57.936] Thread-2 org.eclipse.virgo.medic.eventlog.default UR0001I User region ready.
[Updated on: Tue, 01 June 2010 07:04] Report message to a moderator
| Re: Build Virgo [message #537251 is a reply to message #537109] |
Tue, 01 June 2010 12:49   |
Junior Member |
Hi Chris,
It's log from my desktop win machine (Win XP, Pentium 4, 2GB) where besides kernel at same time running STS, Tomcat, Firefox, Outlook and several applications and corporate policy services (PF usage 1.5 GB approx.). So, when I turned off some of these apps, 'waiting for reference' messages disappeared.
Log from WinXP (PF usage 750 MB)
[2010-06-01 14:09:54.334] startup-tracker org.eclipse.virgo.medic.eventlog.default KE0001I Kernel starting.
[2010-06-01 14:10:02.412] kernel-dm-11 org.eclipse.virgo.medic.eventlog.default SH0001I Kernel ssh shell available on port 2401.
[2010-06-01 14:10:02.583] startup-tracker org.eclipse.virgo.medic.eventlog.default KE0002I Kernel started.
[2010-06-01 14:10:02.740] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-06-01 14:10:03.990] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-06-01 14:10:04.443] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-06-01 14:10:04.583] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-06-01 14:10:04.708] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 14:10:04.771] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 14:10:10.302] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-06-01 14:10:10.318] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-06-01 14:10:10.318] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-06-01 14:10:10.333] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 14:10:10.349] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 14:10:10.349] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-06-01 14:10:10.412] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-06-01 14:10:10.427] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-06-01 14:10:10.458] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-06-01 14:10:10.474] start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-06-01 14:10:11.505] start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-06-01 14:10:11.505] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-06-01 14:10:11.537] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 14:10:11.552] start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-06-01 14:10:11.583] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 14:10:11.583] start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 14:10:11.724] start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 14:10:11.740] start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-06-01 14:10:11.755] Thread-2 org.eclipse.virgo.medic.eventlog.default UR0001I User region ready.
In addition, I have checked on Linux production machine (RH Enterprise 5, 4GB, dual-core).
Kernel started twice faster than on Win machine without 'waiting' messages.
I used same win build (of course after converted bin scripts in unix format).
Log from RHE 5
[2010-06-01 17:44:33.689] startup-tracker org.eclipse.virgo.medic.eventlog.default KE0001I Kernel starting.
[2010-06-01 17:44:38.537] kernel-dm-11 org.eclipse.virgo.medic.eventlog.default SH0001I Kernel ssh shell available on port 2401.
[2010-06-01 17:44:38.636] startup-tracker org.eclipse.virgo.medic.eventlog.default KE0002I Kernel started.
[2010-06-01 17:44:38.750] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-06-01 17:44:38.843] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-06-01 17:44:38.879] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-06-01 17:44:38.900] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-06-01 17:44:38.918] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 17:44:38.934] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 17:44:39.877] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-06-01 17:44:39.882] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-06-01 17:44:39.886] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-06-01 17:44:39.891] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 17:44:39.896] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 17:44:39.901] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-06-01 17:44:39.932] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-06-01 17:44:39.941] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-06-01 17:44:39.951] start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-06-01 17:44:39.951] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-06-01 17:44:40.388] start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-06-01 17:44:40.394] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-06-01 17:44:40.404] start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-06-01 17:44:40.404] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 17:44:40.424] start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 17:44:40.427] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 17:44:40.557] start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 17:44:40.563] start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-06-01 17:44:40.570] Thread-2 org.eclipse.virgo.medic.eventlog.default UR0001I User region ready.
Veso
| Re: Build Virgo [message #577120 is a reply to message #534636] |
Chris
| Re: Build Virgo [message #579159 is a reply to message #537109] |
Junior Member |
Hi Chris,
Log from RHE 5
Veso
| Re: Build Virgo [message #579180 is a reply to message #537251] |
Wed, 02 June 2010 04:25  |
Thanks for letting us know. It's good to know they go away on that hardware, they really should. This is useful to know.
Chris.
Current Time: Sat May 25 22:56:22 EDT 2013
Powered by FUDForum. Page generated in 0.02320 seconds
