Home » Modeling » UML2 » problems with undo on setting default value for a paremeter
problems with undo on setting default value for a paremeter [message #533881] Mon, 17 May 2010 11:29 Go to next message
Ioana is currently offline IoanaFriend
I have the following problem: I set the default value to a parameter using the set command:
SetCommand.create(editingDomain, parameter, UMLPackage.eINSTANCE.getParameter_Default(), defaultValue)
and it's working ok, but when I try to undo, I've seen that the unsetDefault (of ParameterOperations) is trying to do this:
parameter.eUnset(UMLPackage.Literals.PROPERTY__DEFAULT_VALUE);
though the PROPERTY__DEFAULT was not set -- I thought maybe I should set this feature also, but it does not work like this.
And my problem is that it searches for this feature - Property__Default for the parameter, and it does not exist, so the "undo" throws an nullpointerexception.
FYI:
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicUnset(BasicEObjectImpl.java:1208)
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicUnset(BasicEObjectImpl.java:1197)
	at org.eclipse.uml2.uml.internal.impl.ParameterImpl.eUnset(ParameterImpl.java:1598)
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eUnset(BasicEObjectImpl.java:1156)
	at org.eclipse.uml2.uml.internal.operations.ParameterOperations.unsetDefault(ParameterOperations.java:292)
	at org.eclipse.uml2.uml.internal.impl.ParameterImpl.unsetDefault(ParameterImpl.java:834)
	at org.eclipse.uml2.uml.internal.impl.ParameterImpl.eUnset(ParameterImpl.java:1583)
So is something that I might have missed on doing on setting the parameter default value?
Ioana
Re: problems with undo on setting default value for a paremeter [message #533909 is a reply to message #533881] Mon, 17 May 2010 12:50 Go to previous messageGo to next message
--------------090807080001030709060908
Content-Type: text/plain; charset=UTF-8; format=flowed
Ioana,
That looks wrong to me. I think it should be
public static void unsetDefault(Parameter parameter) {
if (parameter.isSetDefault()) {
parameter.eUnset(UMLPackage.Literals.PARAMETER__DEFAULT_VALU E);
Try changing it to see if that fixes the problem and then open a bugzilla.
Ioana wrote:
> parameter.eUnset(UMLPackage.Literals.PROPERTY__DEFAULT_VALUE );
> FYI:
> at
> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicUnset(Ba sicEObjectImpl.java:1208)
> at
> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicUnset(Ba sicEObjectImpl.java:1197)
> at
> org.eclipse.uml2.uml.internal.impl.ParameterImpl.eUnset(Para meterImpl.java:1598)
> at
> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eUnset(BasicEObj ectImpl.java:1156)
> at
> org.eclipse.uml2.uml.internal.operations.ParameterOperations .unsetDefault(ParameterOperations.java:292)
> at
> org.eclipse.uml2.uml.internal.impl.ParameterImpl.unsetDefaul t(ParameterImpl.java:834)
> at
> org.eclipse.uml2.uml.internal.impl.ParameterImpl.eUnset(Para meterImpl.java:1583)
> at
> Ioana
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Ioana,<br>
<br>
That looks wrong to me.  I think it should be<br>
<blockquote><small>    public static void unsetDefault(Parameter
parameter) {</small><br>
<br>
<small>        if (parameter.isSetDefault()) {</small><br>
<small>
parameter.eUnset(UMLPackage.Literals.PARAMETER__DEFAULT_VALU E); </small><br>
<small>        }</small><br>
</blockquote>
bugzilla.<br>
<br>
<br>
Ioana wrote:
<blockquote cite="mid:hsr9au$gjo$1@build.eclipse.org" type="cite">Hi,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
FYI:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Ioana </blockquote>
</body>
</html>
--------------090807080001030709060908--
Re: problems with undo on setting default value for a paremeter [message #534150 is a reply to message #533909] Tue, 18 May 2010 08:43 Go to previous messageGo to next message
Indeed it was working with value changed to PARAMETER_DEFAULT_VALUE.
So I've added a bugzilla with this issue.
Ioana
Re: problems with undo on setting default value for a paremeter [message #628451 is a reply to message #533909] Tue, 18 May 2010 08:43 Go to previous message
Ioana
Previous Topic:problems with undo on setting default value for a paremeter
Next Topic:Newbie - Problem creating models
Current Time: Thu Feb 22 18:19:10 GMT 2018
Powered by FUDForum. Page generated in 0.01657 seconds
