Home » Archived » BPMN Modeler » Several Outgoing Edges
Several Outgoing Edges [message #533874] Mon, 17 May 2010 10:58 Go to next message
Christine  is currently offline Christine Friend
I have an XOR-Gateway in my Diagram with one incoming and two outgoing edges:
<vertices xmi:type="bpmn:Activity" xmi:id="_u3UQwWF6Ed-YKsNjaSTdBQ" iD="_u3UQwGF6Ed-YKsNjaSTdBQ" outgoingEdges="_wCviEWF6Ed-YKsNjaSTdBQ _wZgcQWF6Ed-YKsNjaSTdBQ" incomingEdges="_vng-oWF6Ed-YKsNjaSTdBQ" activityType="GatewayDataBasedExclusive"/>
However, when I try to count the outgoing edges, the result is always 1:
(activity.getOutgoingEdges()).size()
When I look at the SequenceEdge ID on Index 0, I can see the second ID: _wZgcQGF6Ed-YKsNjaSTdBQ
The first ID is not returned. Is it somehow possible to iterate through all outgoing edges?
Christine
Re: Several Outgoing Edges [message #534010 is a reply to message #533874] Mon, 17 May 2010 17:35 Go to previous messageGo to next message
Antoine Toulmé is currently offline Antoine ToulméFriend
Member
That's weird.
Can you make sure the first sequence edge exists ? What do you see in the advanced tab of the properties for that task ?
Antoine
Re: Several Outgoing Edges [message #534746 is a reply to message #534010] Thu, 20 May 2010 08:42 Go to previous message
Hi Antoine,
You are right, I found both Sequence Flows in the Advanced Tab. I seems that I made a mistake in the transformation by extracting the default flows first .
Christine
Previous Topic:how genrate ID??
Next Topic:BPMN model validation
Current Time: Fri Jun 22 02:11:56 GMT 2018
Powered by FUDForum. Page generated in 0.01494 seconds
