Home » Archived » M2M (model-to-model transformation) » [ATL] Problem when loading UML Profile programmatically for ATL transformation
[ATL] Problem when loading UML Profile programmatically for ATL transformation [message #533754] Sun, 16 May 2010 18:03 Go to next message
Helko Glathe is currently offline Helko GlatheFriend
Member
I've a problem with my source code for starting an ATL transformation programmatically whithin Eclipse.
The basis for the transformation is simply an input model which is a UML Profile.
This is the code I currently have:
public class Test {
	public static void main(String[] args){
		   // Initial Setup
		try {
			ResourceSet resourceSet = new ResourceSetImpl();
			resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
			resourceSet.getPackageRegistry().put(EcorePackage.eNS_URI, EcorePackage.eINSTANCE);
			resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put(
			UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
		//ILauncher launcher = CoreService.getLauncher("Regular VM (with debugger)");
		ILauncher launcher = new EMFVMLauncher();
		//ModelFactory factory = CoreService.createModelFactory(launcher.getDefaultModelFactoryName());
		ModelFactory factory = new EMFModelFactory();
		//IInjector injector = CoreService.getInjector(factory.getDefaultInjectorName());
		IInjector injector = new EMFInjector();
		//IExtractor extractor = CoreService.getExtractor(factory.getDefaultExtractorName());
		//metamodels
		final IReferenceModel umlMetamodel = factory.newReferenceModel();
		injector.inject(umlMetamodel, "http://www.eclipse.org/uml2/3.0.0/UML");
//		final IReferenceModel mpMetaModel = factory.newReferenceModel();
		// Creating models
		IModel eadlProfile = factory.newModel(umlMetamodel);
		IModel myEadl = factory.newModel(umlMetamodel);
		//load the input-file
		injector.inject(eadlProfile, "file:/C:/east.profile.uml");
		Map<String, Object> options = new HashMap<String, Object>();
		options.put("allowInterModelReferences", "true");
		options.put("profile", "true");
		options.put("supportUML2Stereotypes", "true");
		// Getting launcher
		launcher.initialize(options);
		// Launching
		launcher.addInModel(eadlProfile,"IN2","EADLPROFILE");
		launcher.addOutModel(myEadl, "OUT", "MYEADL");
		//launcher.addLibrary("HelperFunctions", launcher.loadModule(asmF));
		IFile currentAtlFile = ResourcesPlugin.getWorkspace().getRoot().getFile(Path.fromOSString("C:/rif2eadl.asm"));
		InputStream asmInputStream = null;
		try {
			asmInputStream = currentAtlFile.getContents();
		} catch (CoreException e) {
			// TODO Auto-generated catch block
			e.printStackTrace();
		InputStream[] modules = new InputStream[1];
		modules[0] = asmInputStream;
		launcher.launch(ILauncher.RUN_MODE,
						new NullProgressMonitor(),
						options,
						(Object[])modules);
		} catch (Exception e) {
			System.err.println(e.getMessage());
The problem is that the main method stops with an error at the line, where the east.profile.uml file will be loaded/injected.
The error message is:
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.eclipse.org/uml2/schemas/Ecore/5' not found. (file:/C:/east.profile.uml, 8029, 198)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(X MLHandler.java:2590)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefi x(XMLHandler.java:2421)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:1299)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:1468)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1019)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:87)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:1001)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:712)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:169)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocume ntParser.emptyElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1494)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1282)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:255)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:270)
... 4 more
When I start the ATL transformation via the Eclipse ATL Launch Configuration Wizard, the problem does not occur.
Does anyone know, how to solve the problem? If more informations are needed, please ask me.
Thanks in advance, Helko
Re: [ATL] Problem when loading UML Profile programmatically for ATL transformation [message #534444 is a reply to message #533754] Wed, 19 May 2010 08:49 Go to previous messageGo to next message
Elhamlaoui Mahmoud is currently offline Elhamlaoui MahmoudFriend
HI, Helko
Did you soleve your problem, because i have the same, its like the programmedont know the Eoperation stuff, its transform just the Eattribute. Sad
mahmoud
Re: [ATL] Problem when loading UML Profile programmatically for ATL transformation [message #534451 is a reply to message #533754] Wed, 19 May 2010 09:16 Go to previous messageGo to next message
Sylvain EVEILLARD is currently offline Sylvain EVEILLARDFriend
Have you tried to inject the UML metamodel as an EMF resource ?
injector.inject(umlMetamodel, resourceSet.getResource(URI.createURI("http://www.eclipse.org/uml2/3.0.0/UML"), false));
icon14.gif  Re: [ATL] Problem when loading UML Profile programmatically for ATL transformation [message #534480 is a reply to message #533754] Wed, 19 May 2010 10:30 Go to previous message
Member
I've solved the problem:
ResourceSet rss = ((EMFModelFactory)umlMetamodel.getModelFactory()).getResourceSet();
		rss.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
		rss.getResourceFactoryRegistry().getExtensionToFactoryMap().put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
		Map<URI, URI> uriMap2 = rss.getURIConverter().getURIMap();
		URI uri = URI.createURI("jar:file:/D:/.../eclipse/plugins/org.eclipse.uml2.uml.resources_3.0.0.v200906011111.jar!/");
		uriMap2.put(
			URI.createURI(UMLResource.LIBRARIES_PATHMAP),
			uri.appendSegment("libraries").appendSegment(""));
		uriMap2.put(
			URI.createURI(UMLResource.METAMODELS_PATHMAP),
			uri.appendSegment("metamodels").appendSegment(""));
		uriMap2.put(
			URI.createURI(UMLResource.PROFILES_PATHMAP),
			uri.appendSegment("profiles").appendSegment(""));
		rss.getPackageRegistry().put(EastadlPackage.eNS_URI,EastadlPackage.eINSTANCE);
Hope that helps.
But know, I have a pfroblem with applying UML Profile Stereotypes to UML elements ... see my new post (in a few minutes Smile
Best regards, Helko
Previous Topic:QVT-R Resource Implementation
Next Topic:[QVTo] How to determine <unset> Integer
Current Time: Thu Feb 22 19:05:00 GMT 2018
Powered by FUDForum. Page generated in 0.03257 seconds
